'67 Z21 Camaro 5.3L/4L60e Implant
Title says it all almost...
My recently acquired '67 will get this drive train after I swap out the 709 Heads with engine code "B" 799's and the cam's as well. This should give the little 5.3 about 325 hp.
Also considering a rear change.
I am a real fan of the IRS (not the taxing one). I'm talking independent rear suspension.
I have a line on an '85 XJ6 rear end which should fit nicely between the frame rails once I weld in a cross member.
Here is a picture of the car.... it has needs ... new floor pans and trunk pan, left quarter, right inner & outer wheel wells, rockers and general rust prevention/elimination.
