LS3 ex. manifold on a LQ4 - 65 Chevelle Build
Old 08-21-2011, 03:20 PM
SIKHS 5's Avatar
Default LS3 ex. manifold on a LQ4 - 65 Chevelle Build
im putting in a LQ4 in my 65 Chevelle - the engine came with stock manifolds, locally a guy is selling new ls3 exhaust manifolds -- i would wondering if those would fit better in the chevelle.
these are the manifolds - i should be about to get them for about $80 [planning on using BRP mounts along with a LH8 oil pan if that matters]
thank you
Old 08-21-2011, 08:23 PM
Rick Speed's Avatar
They will bolt up no problem. As long as the outlets face the direction you want them to should work great.
Old 08-21-2011, 11:25 PM
SIKHS 5's Avatar
does anyone know if they will clear? has anyone tried using these before in the same setup?
Old 08-23-2011, 12:20 AM
SIKHS 5's Avatar
TTT - before he sells it
Quick Reply: LS3 ex. manifold on a LQ4 - 65 Chevelle Build
