What harmonic balancer for 6.0 LS1????
What harmonic balancer for 6.0, LS1???? I got almost all my swap parts for the 6.0
The motor is a 6.0 09 model. I want to use all the F-Body accessories as its going into a 81 vette. So Can I use a F-Body balancer?? will this work??
http://cgi.ebay.com/ebaymotors/Chevr...item23130ddf0c
http://cgi.ebay.com/ebaymotors/Chevrolet-LS1-Camaro-SFI-damper-Power-Bond-Firebird-010-/150643531532?pt=Motors_Car_Truck_Parts_Accessories &hash=item23130ddf0c
Hello Sir. In that Corvette you should use the front drive acc for a 97 and up Corvette. That way you want get any problems with the alternator and the AC. Maybe the Camaro setup will work, newer done that, uses only Corvette for the Corvette. But truck acc is for truck damper and vette is for vette and F is for F, they are not interchangeable. Or yes you can, but then you need spacers for the water pump and the rest of you're need machine work.
