Changing my fox to 6.0 .. Front springs???
Old 09-02-2011, 07:57 AM
zapp109's Avatar
Default Changing my fox to 6.0 .. Front springs???
Im going turbo 6.0 curious what springs you guys run. Right now i have a 125# x14" coilover spring. I want to change to 12" anyway but figured since im going iron block and adding a little more weight ( still running 243 heads as of now) I may want to get maybe a 150-175#... Let me know what your setup is thanks
Old 09-02-2011, 08:26 AM
Dickie-311's Avatar
i have a 6.0 not turbo , but i run 14" 150# springs and they work fine, car sits good
Old 09-02-2011, 08:41 AM
LS1-450's Avatar
Depends...
Are you setting the whole suspension up for performance, (turning left & right) or are you just trying to support the front for straight line driving? There is a huge difference between these two set ups. If just wanting to support the increased weight up front, 150-175# will result in about what you had.
Old 09-02-2011, 11:45 PM
trav-tech's Avatar
I'm running 12"x150 with a turbo 5.3 iron block. It's been working good so far.
Old 09-03-2011, 09:43 AM
zapp109's Avatar
Well its a street drivin bracket car I drive to track and around town. So I like the way it feels now probably go with the 150 12"
Old 09-03-2011, 10:34 AM
Unstang's Avatar
I drive mine all the time on the street/hwy, it has 150#, 12" springs in it.
Quick Reply: Changing my fox to 6.0 .. Front springs???
