LS1 Motors - how do you buy a "Good" used one?
Old 09-03-2011, 01:10 PM
Geoff55's Avatar
Default LS1 Motors - how do you buy a "Good" used one?
I've been wondering about this:
If you were buying a used LS1 Motor/trans that is no longer in the car,
what are some things to look for to make sure it is good?
What items do you want to make sure come with the motor?
What years are the most desireable?
Anything to avoid?
Old 09-03-2011, 01:21 PM
Novaman's Avatar
I gotta hear them run. If I can't hear a motor run I won't buy it. Sitting in a totalled out car in a junkyard is a good sign that it probably ran. Ad on craigslist, motor out of the car is a good sign theres something wrong with it.
I'd get the whole motor, intake to pan, flexplate to fan, wiring harness, pcm, mass air meter, gas pedal if dbw, If you can get the trans you want with it out of the same car, do it. The more parts the better, saves money later.
Old 09-03-2011, 01:26 PM
ls1ya's Avatar
Try to see/get leakdown/compression test. Check existing fluids.
Old 09-03-2011, 01:36 PM
sscamaro1384's Avatar
ask alot of questions,hell have a buddy go and see the seller and ask similar questions. see if the answers are consistent. Why did u pull it,mileage, pull the oil pan,valve covers.and avoid 98 yr model.look for 01-02 if its a camaro,trans am
Old 09-03-2011, 01:42 PM
Zlow28's Avatar
why avoid the 98 year model??
Old 09-03-2011, 02:22 PM
Geoff55's Avatar
Yeah, this has me curious, too.
How about '99-'2000 models?
Old 09-03-2011, 02:32 PM
Zlow28's Avatar
maybe he means the piston slap, but i couldve sworn 98s were the ones who least suffered from this. Could be wrong though.
I know 98 fbodies didnt have a dummy temp. gauge and all kinds of other small things like that, but i doubt that has anyhting to do with the engine.
Old 09-03-2011, 03:10 PM
nissan 570sx's Avatar
The big differences are that 98's run a different PCM operating system(?) that's supposedly harder to tune and they have weaker rod bolts. 01-02's have LS6 intake and no EGR.
https://ls1tech.com/forums/1740880-post2.html
Old 09-03-2011, 04:11 PM
Zlow28's Avatar
^^ thanks, thats the link i was looking for
Old 09-04-2011, 12:04 AM
hotswap's Avatar
Look for the complete set up out of a wrecked car. Then, if you haven't heard it run or have no confirmation that it's in good running condition(leak down, compression check), use it as a bargaining tool. You might just have to rebuild it. If the story doesn't add up, walk.
Old 09-06-2011, 05:15 PM
sparkwirez06's Avatar
The 98 also had the small oil galley, under the rear cover. was enlarged for 99-up. the 98 rear cover is not interchangable with other years.
Old 11-20-2011, 01:19 PM
Geoff55's Avatar
Thanks for the advice..
I was able to find a nice 70k mile '99 LS1/4L60 combination with EVERYTHING with it.
Going to put a cam, LS6 intake and 243 heads on it.
Old 11-20-2011, 01:33 PM
rotor vs. piston's Avatar
Word of mouth for a good seller if you're unable to hear it run yourself. I got my pullout off of ebay and researched the seller (can't recall who it was now) and it all checked out and pulled the trigger. So far, so happy.
Quick Reply: LS1 Motors - how do you buy a "Good" used one?
