2 questions on steam lines
Old 09-05-2011, 07:41 PM
samckitt's Avatar
Default 2 questions on steam lines
1. Is there picture anywhere of all the different styles of steam lines?
2. The LT1 had the crossover steam line on the back of the heads. The LS engines have it on the front & the back holes plugged. Is there any advantage to having it in the back with the front plugged, or with a line coming from both?
Thanks,
Scot
Old 09-05-2011, 08:14 PM
01cherryreds10's Avatar
Supposedly having the backs plugged can cause hot spots on the rear cylinders. I doubt it will matter unless you're making serious power.
The f-body line connects all four under the intake.
The truck connects the front two and the hose comes out up top.
The Corvette connects the fronts and the hose goes towards the front of the engine.
Old 09-05-2011, 08:17 PM
Irish350's Avatar
different angle position/intake setups are usually the reason why either the fronts/backs/all are connected.
they all look pretty much the same with the exception of the fbodies which didnt have 2 caps and 1 tube (either front or back) but had a "spider" that hit all 4 corners and had an outlet. Im not sure of a picture reference but if youve seen one of them they look the same with slightly different bends (ie, i think trucks had a deeper bend because of the intake)
ideally theyre all connected so you can release steam from each section of the head, but gm didnt think it was necessary based on the usage of the engines, the angle they sit in vehicles, etc. If youre racing id connect them all.
EDIT: also **** lt1s and their banjo bolts, i remember having a hell of a time on the back of those heads lol
Old 09-05-2011, 08:39 PM
Rick Speed's Avatar
The LT1 only had it coming from the back because it was reverse cooled and it needed them.
Old 09-05-2011, 09:02 PM
samckitt's Avatar
Not sure why the "reverse" makes any difference. Reverse meant it went through the heads first, then the cylinder walls. Instead of through the block & then the heads.
Old 09-05-2011, 10:02 PM
Rick Speed's Avatar
I Beleive because it caused steam pockets so they needed to vent them
Old 09-05-2011, 10:12 PM
Kleeborp the Moderator™
MeentSS02's Avatar
They changed this setup in 2001 when they started using the LS6 intake on all LS1 f-bodies...the LS6 intake had a dropped floor compared to the LS1 intake, so there was no longer room to run the hard line under the intake. The rears on mine are capped, and only the front two are connected. I will likely look for a way to hook the rears back up, but it has to be clean, and so far, I've not been able to figure out a way to do it without making it look like a bird's nest of tubing and fittings.
Old 09-05-2011, 11:05 PM
Rick Speed's Avatar
I've seen people use the one that connects all 4 corners under the LS6. They had to "clearance" the ribbing under the LS6
Old 09-06-2011, 05:39 AM
Pop N Wood's Avatar
I've seen ones where people cap all 4.
Seeing a pattern here?
Old 09-06-2011, 10:28 AM
1A Dan's Avatar
definitely should not be capping all 4, that's just asking for trouble. I opted to use all 4 on my setup; ls3 tube in front, l92 in rear, semi rigged setup to connect the two for now. Will be going with something like this later to clean things up:
http://www.krcpower.com/catalog_i112...l?catId=366482
Old 09-06-2011, 10:39 AM
Super Moderator
Reckless's Avatar
Or: http://www.kurturbanperformance.com/...or-system.html
Old 09-06-2011, 05:34 PM
samckitt's Avatar
I'm definetly not going to cap off all 4, I would rather have too much than not enough.
I think I'll try the F body one and clearance the intake a bit for it. Anyone have a P/N?
Thanks
Old 09-06-2011, 09:19 PM
bwirolla64's Avatar
So looking at the link from reckless how do you install it? Does the nipple pop on or do you have to remove the piece? I looked at the back of my LS3 and there is an open threaded hole for the bolt but where the steam port is it looks like a popit
Old 09-07-2011, 01:07 AM
Dillon93dillon's Avatar
Do these steam lines just need ran into a overflow bottle? Or back into the cooling system?
Old 09-07-2011, 07:27 AM
bwirolla64's Avatar
From what I have read it should go back into the system. I don't know how often it releases but I would think often and if so then just a bottle would fill up quick.
Old 09-07-2011, 10:29 AM
Okay. That's how I'll do it then
Old 09-07-2011, 10:39 AM
1A Dan's Avatar
the cheapest ones i found will require adapters to get to AN, but may still be worthwhile for some:
http://s41657.storefront-solutions.c...l.aspx?ID=3289
Old 09-07-2011, 10:43 AM
bjamick's Avatar
I used the 98-00 steam tubes on my 99 with ls6 intake. Just grind down the ribbing under the intake. This way it gets coolant to front and back of head, no hot spots.
Old 09-07-2011, 10:50 AM
lxwithlaundry's Avatar
what if i'm using a radiator that doesn't have the lines for the hook up to the vents? can i just T it into the over flow on the radiator?
Old 09-07-2011, 12:06 PM
bwirolla64's Avatar
I don't have a fitting on my radiator but I am welding a fitting in or like some of the other guys have drilled and tapped there water pump! But they have debated on which is better water pump or radiator
Quick Reply: 2 questions on steam lines
