87 buick regal
Old 09-18-2011, 01:56 PM
my406cid's Avatar
Default 87 buick regal
good afternoon.long time veiwer but now i need some help lol.the time has come to start my lq9/4l60e/l92/lingenfelter gt-11 combo.i am using the l92 truck intake with the 90mm l92 truck t body.the lq9 has the factory harness and computer right now,but the l92 t body has a 6 pin connector and the lq9 t body has 8 pin connector.will i need to have a custom harness made to use the l92 t-body?also has anyone used or heard of the adjustable dirtydingo cov
nversion mounts?they look to clear the low mount a/c compressor and work with the cts-v oil pan that i have.anyone that has any insight or tips please.reply.thanks
Old 09-22-2011, 03:10 PM
my406cid's Avatar
help please someone?
Old 09-22-2011, 03:19 PM
debreshnev's Avatar
If your LQ9 throttle body came out of a 2007+ vehicle they are going to use a different connector on the throttle body. I know a guy local to me that ran into this working with a 2010 LS3 from a Camaro he had PSI make him a custom harness to deal with it.
On the Dirty Dingo conversion mounts, I used them on my car though it was not a regal they worked out great I did not have AC but could see they would leave clearance for it depending on how far forward or back you mount they. They have a lot of adjustability and allowed me to move the engine forward and back till I found the perfect position then just tighten them down. I did modify mine a bit as I had really narrow frame rails and their frame bolt holes were not narrow enough so I had to drill some new holes and cut off the ends of the mounts but it was no big deal. They do not come anywhere near the oil pan so you should not have any problem there.
Old 09-22-2011, 06:36 PM
my406cid's Avatar
so all i need is someone to make ans or modify my harnessto fit that t body.no additional computer mods?
Old 09-22-2011, 09:42 PM
the_merv's Avatar
You will have to tune it..to make it run right.
Quick Reply: 87 buick regal
