LS2 cam ? for my turbo 4.8 build
I was wondering if a LS2 cam would be a decent upgrade for my turbo 4.8 that I'm building for my 74' Datsun 260z ? I know the LS6 cam would be best but I was just wondering cause they're abundant, cheap, and just a little smaller than the LS6.
That is what I thought, at least lift and duration wise
Here is a pretty good article comparing all the cams. Says the LS2 is actually superior to the LS6, on a 5.3 anyway
http://www.hotrod.com/how-to/engine/...st-comparison/
Make sure you upgrade the valve springs no matter what cam you use
I ended up going with a 04 Z06 cam with 799 valve springs in 241 heads. Its already installed in my 4.8 so I'll consider it a huge improvement over stock. I haven't started the engine yet but its coming soon.
