Mating a SBC/BBC Trans (T10, Muncie, Richmond, TKO) with an LS motor
i know this isnt too current of a thread but im kind of stuck here. what flywheel do i need to mount my ten spline muncie to a 2000 4.8 engine? im stuck here and not sure what to do. any help would be GREATLY appreciated!!
Great info. Where was all of this when I was setting mine up years go I did basically the same things except I used a Lakewood scatter shield because of the clocking on a Chevy II. One thing I did differently was to install a 40 tooth reluctor wheel on the tailshaft of my Muncie. I got the reluctor from Jags that Run. It clamps onto the tailshaft between the reverse gear and the speedo gear with a little shim stock. Then I drilled and tapped the extension housing for the VSS. Works good and the PCM likes it.
I was trying to do something similar in the T10, but the odd tailhousing of the 82 T10 I had was cast for a torque arm attachment. It had a raised floor through the entire housing. That left no room for evan the smallest reluctor I could find. I was considering using the ouput flange splines but figure the bigger reverse gear would have a greater output voltage (higher rotational speed) and wasn't sure of the ecus sensitivity.
If you have a pic of your reluctor mounted on the Mucie shaft or the vss on the housing, feel free to add them here.
Good to see another old school trans behind an LSx.
Yeah, like I said I ordered, hopefully I get it. I am trying to do a budget swap into another car as it will be a DD most likely.
#33
My local Oreilly's had a bunch on the shelf (I picked up one) and indicated they have em at their warehouse.
Are we talking total weight (Flywheel + Clutch kit)? The flywheel feels like weighs about 25lbs.
#36
#39
I have a sachs 1050 flywheel for my turbo'd LQ4. Im using this because of its thickness to work with my Muncie. Im looking for a clutch to match this flywheel that will handle about 800+Hp. Im running an auto gear M22 tranny with 1-1/8" 26 spline input shaft manual clutch linkage.
Just for fun I tried my lining up my old SBC clutch to this flywheel, it looks like the bolt pattern is the same, but the pressure plate did not line up correctly.
What are my high horsepower clutch options for this flywheel? I prefer a twin disk for a lighter pedal. I plan to run slicks at the track.
#40
Was your old clutch 10.5 or 11"? 153 or 168 tooth flywheel?
Brw, at 800 hp, you're pushing the trans as much as the clutch.
