Running 5.3L truck engine with LS1 intake and 5.7 injectors
Old 10-14-2011, 10:59 AM
the-jag-guy's Avatar
Default Running 5.3L truck engine with LS1 intake and 5.7 injectors
I know all of the parts basically interchange mechanically. What I',m wondering is whether the LS1 intake and 5.7 injectors can be run on a 5.3 with a (for the most part) stock 5.3L tune in the PCM. The engine displacements are very close.....
Has anyone tried it?
Old 10-14-2011, 11:30 AM
LS1Tech Sponsor
psiconversion's Avatar
Which MAF are you going to run?
Among other things, tune will have to be updated for the LS1 injector constant.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 10-14-2011, 11:42 AM
Default 5.3L running LS1 intake and 5.7 injectors
What I'd want is to (ideally) put together a set up that would not require any retuning.
I have plenty of Camaro MAF, but if the truck unit is needed to go this way, so be it.
Old 10-14-2011, 12:27 PM
garys 68's Avatar
You can run the truck flex fuel injectors on an LS1 intake without changes. You just need an aftermarket fuel rail ($99 on ebay). The LS1 fuel rail wont reach the shorter truck injectors. Or you could use the truck fuel rails. Earlier truck injectors will work too, you just need to remove the plastic tips.
05 L59, truck injectors, harness, TB, MAF, f body LS1 intake.
Old 10-14-2011, 01:05 PM
parks450's Avatar
Just get injector adaptors from fci their fairly cheap and nice pieces,have some myself.
Old 11-01-2011, 08:50 PM
STUNTMAN's Avatar
I have a 2000 truck 5.3 I want to swap the intake out on. You are saying that I can put my truck fuel rails and injectors in the LS1 intake. I just have to remove a plastic tip? I haven't pulled my injectors out yet, and I have never seen any out of a truck intake. with that being said, is it easy to tell what I need to remove?
Old 11-02-2011, 12:53 AM
garys 68's Avatar
A little more info with pics.
http://www.performancetrucks.net/for...e-swap-359987/
Old 03-14-2013, 07:31 PM
Z28-Vortec's Avatar
Sorry for bringing this older thread but I just want to make sure I am understanding this correctly.
So all I would have to do to use the flex fuel truck injectors part #12613411 on a LS1 intake is after market fuel rails like in the picture?
LS1 injectors are 60mm and truck are 48mm. Correct me if I am wrong.
The main thing I am wondering is how are the rails mounted to accommodate the height difference of the LS1 injectors vs the truck? Cut or trim the intake at all or custom mounting brackets for the fuel rails?
Thanks
Old 03-15-2013, 02:45 AM
garys 68's Avatar
"Custom" mounting brackets for the rails might be an overstatement. They're just little L shaped pieces of metal. But yeah, you just need to make shorter ones.
Old 03-15-2013, 08:11 AM
ctd450's Avatar
Are those $99 eBay rails any good? Are the an adapters o-ring or pipe thread? I am building an Ultra4 car and another U4 racer had his rig burn to the ground a few years ago because he ran cheap fuel rails that were npt on the ends, and one of them cracked around the an adapter.
Normally cheap parts scare me and fuel systems are one of those areas where i prefer to spend more money on good stuff and worry about paying for it later on, but if these rails are as good as the FAST or Aeromotive fuel rails they might be worth a shot.
Old 03-15-2013, 08:19 AM
Z28-Vortec's Avatar
K I wanted to double check, I couldn't quite tell from the picture.
Old 03-15-2013, 09:43 AM
garys 68's Avatar
They're ok, no leaks. But yeah they are NPT and I could see how cranking one down too hard could crack it. I would definitely upgrade if I needed new ones.
Old 03-16-2013, 01:11 AM
diesel240's Avatar
Finally an answer!!!
Old 03-16-2013, 06:11 AM
99VetteFRC's Avatar
I put the LS1 intake rails and injectors right on my 4.8. It started and ran fine for a few months before I changed the injectors and put the turbos on. I bought EV1 connectors for $17 (for all 8) and put them in the harness. Very painless.
Old 03-16-2013, 03:55 PM
Z28-Vortec's Avatar
Where did you buy your connectors?
Old 03-17-2013, 09:28 AM
99VetteFRC's Avatar
These are the exact ones I bought.
http://www.ebay.com/itm/8-Injector-connectors-Ford-Chevy-VW-GM-Buick-Jeep-Ev1-/290553010504?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a64f1948&vxp=mtr
Old 03-19-2013, 10:35 PM
Z28-Vortec's Avatar
Thank you!
Old 04-23-2013, 09:06 AM
jiveass's Avatar
i know this is old, but im runnin a 5.3 in my trans am, ls1 intake and injectors, maf...all the factory ls1 stuff on the 5.3...even ls1 tune.....car seems to run fine..has been for a year now as my daily driver....im not sayin it couldnt run better if tuned, but for me, its worked just fine the way it is.
Old 08-29-2013, 09:31 AM
autogeek23's Avatar
i understand this is old like stated above. i am going to be swapping in a 5.3 from a 2010 silverado. my ls1 stuff is going on it. intake etc. i understand the cam sensor is now in the front timing cover and the cam gear might be different. i want to use my 3 bolt cam from my ls1.
i have been searching for a while now still looking to find the adapter harness for the cam and crank sensors so they will work with my stock harness. also the adapters/extensions for the knock sensors that are now relocated to the side of the motor. i found them somewhere on here but cant find it again
any help is appreciated. i will continue to search in the mean time
Old 08-29-2013, 09:56 AM
fastcrash30's Avatar
That cam swaps not gonna be easy with your 3 bolt cam. Someone correct me if I'm wrong but that 5.3 will have a single bolt cam w/4x cam gear that will only work with the 58x crank pickup wheel. Older ls1 had 3 bolt cam with 1x cam gear and 24 or 28x crank pickup wheel I can't recall which it was of the two. And the ls1 cam pickup is at the rear along with the sensor. Be easier to keep the cam in it or buy one for that application.
Quick Reply: Running 5.3L truck engine with LS1 intake and 5.7 injectors
