1969 camaro transmission line adapter
Old 10-23-2011, 06:06 PM
bodies67's Avatar
Default 1969 camaro transmission line adapter
Hey, I need Your help. I have a 1969 camaro that I put a LS2 6.0 / automatic in . I need some adapters to hook the transmission lines up. The GTO hoses have some weird ends on them, Larger Metric inverted males on them. My radiator has 3/8 inverted females in it. I need some adapter to go from the GTO ends into the Camaro radiator. Has Anyone ran into this? I guess I could cut the ends and reflare it. but I wanted to keep it stock Incase I need to get one at a parts store on the road. Any help would be apperciated!! Thank's Tommy
Old 10-23-2011, 06:23 PM
Rocketrod's Avatar
What type of trans: 4l60e, 4l70e, 4l80e, etc?
Old 10-24-2011, 07:34 PM
bodies67's Avatar
4L60E. the Stock one that came in a 2005 Gto . Thought it was a 4L65E. I might just have to cut the ends off and flare the end and put on some flare nuts. The line size is 3/8. Did not want to, but I don't know what else to do. have you ran into this?
Old 10-24-2011, 09:07 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
see if any of these will work:
http://www.purechoicemotorsports.com...cat/cat101.htm
Andrew
Old 10-25-2011, 03:34 AM
LS1MCSS's Avatar
Cut the metric ends off, re-flare them and use the correct ends for the radiator. That way, you won't have to worry about getting anything while on the road because they will be trouble free.
Old 11-01-2011, 06:36 AM
bodies67's Avatar
Andrew
No none of these are built like it. I guess I'm going to have to cut them and flare it. Thank's for trying!!
Quick Reply: 1969 camaro transmission line adapter
