Do iron brocks brake at the mount?
Old 11-16-2011, 09:05 PM
LSCha0s's Avatar
Default Do iron brocks brake at the mount?
I was looking for starter bolt size and ran across multiple threads where the block mounts break with the first design starter. My questions is, is this also true for iron blocks? I have a starter with the inboard "small" mounting tab. Do I need to get a better starter?
Old 11-17-2011, 07:58 AM
LSCha0s's Avatar
TTT
Old 11-17-2011, 09:32 AM
Rikoshay's Avatar
Correct. The dual long bolt starter is the Updated starter nose cone design.
There is a TSB regarding this.
I will search to see if I can find another bulletin that talks about replacing the crank position sensor for a potential backfire condition that breaks starter nose cones.
File Type: pdf
Old 11-17-2011, 09:35 AM
ASSuming On The Tree
audacious nick's Avatar
Asian moment?
Old 11-17-2011, 09:39 AM
Jones'n's Avatar
those brocks are bad, especiarry the cadirrac brocks.
Old 11-17-2011, 09:52 AM
LSCha0s's Avatar
lol u bruncha wrumb brassas
Old 11-17-2011, 09:56 AM
LSCha0s's Avatar
My question was.. does this also effect the iron blocks? I have a 5.3 iron block.
Old 11-17-2011, 09:18 PM
Rikoshay's Avatar
Yes, this affects iron blocks as well. The TSB is for Chevy Trucks.
Old 11-18-2011, 07:05 AM
LSCha0s's Avatar
Ok, thanks for your help.
Quick Reply: Do iron brocks brake at the mount?
