I need your input on a single exhuast design, please.
Old 11-22-2011, 08:02 PM
arthropraxis's Avatar
Default I need your input on a single exhuast design, please.
The motor is a 2004 GTO with medium length headers, no emissions and stock cam. The plan is to take it from the collectors to 2.5" pipes to a Y and out with a single 3".
What I would like is a good sound without being too loud, this is a daily driver. The muffler that is planned is a Borla turbo with an offset in and center out.
Would a single muffler out back be enough to quiet it down or should I use a mid muffler? Both would be straight through design.
This is what it sounds like with open headers:
http://youtu.be/RpOlQK_5sgE
Old 11-22-2011, 11:10 PM
LS1 TJ's Avatar
Did the same for my LS6 wrangler. 2.5" into an flow master merge into a 3" Flow master 3" the back of the wrangler. First flow master was delta 50 and t was bit loud. More than bit. Changed it out to 70 series and bbbiiiggg improvement.
Old 11-23-2011, 09:42 AM
So, you used a single muffler. How loud would you describe the 70 series muffler? Do you see any need for an additional mid muffler?
Old 11-23-2011, 11:02 AM
cam
cam's Avatar
For singles the only muff I like that flows well, sounds mean, but most importantly has NO DRONE is the Hooker Aerochamber. Plus as a side bonus they are pretty well priced.
LS1sounds.com
Old 11-23-2011, 11:59 AM
Thanks, I will look at them.
Old 11-23-2011, 12:10 PM
JIMB's Avatar
On the Jeep it has good sound. No drone to speak of but that 70 series is big.
I don't see a need for mid muffler. The 3" 70 series is 3" all the way thru. Not 2.5" with the ends expanded like some 3" mufflers.
Old 11-23-2011, 02:53 PM
Thanks, that is what I need to know. No need to buy two mufflers if one will do the job. It doesn't need to be whisper quiet. I don't want to be obnoxiously loud and I have no point of referrence.
