Individual Connector Pinout
Old 11-25-2011, 09:58 PM
wilson34's Avatar
Default Individual Connector Pinout
I need access to a pinout of each connector for all the sensors on the engine.
Old 11-25-2011, 10:46 PM
i r teh noobz's Avatar
You need to be more specific. Pinouts and wire colors vary by year and engine. Check out the wiring info at lt1swap.com and see if it helps.
Old 11-25-2011, 11:35 PM
bczee's Avatar
Get a Factor Services Manaual. It will have everything your asking for.... or find someone that has access to Alldata..
Old 11-25-2011, 11:47 PM
traenknerperformance's Avatar
we have alldata at my shop- PM me with your make model and year the engine is out of and i can get you some schematics emailed to you
Old 11-26-2011, 12:01 AM
wilson34's Avatar
Thanks..
The car is a 2002 Pontiac WS6.
I need to know information such as pin 1 of Blue PCM connector goes to Pin 4 of Metripack Sealed connector for O2 sensor.
Groundhogs stole a large portion of the wiring harness so I can not just go by matching wiring colors at this point.
Old 11-26-2011, 07:49 AM
bayer-z28's Avatar
See if this helps. Camaro, so some of it may be different.
http://cs.chevroletclub.net/graphics...g.diagrams.pdf
Old 11-26-2011, 08:27 AM
Smo's04Gto's Avatar
sign up with alldata only cost $25.
Old 11-27-2011, 03:37 PM
wilson34's Avatar
Found what I needed online...Thanks guys
