5.3 will not run part 2
Old 12-11-2011, 03:41 PM
68_firechicken's Avatar
Default 5.3 will not run part 2
I posted this same thread last week and executed all of the suggestions i received and nothing. I checked the ign. and power wires on the coils. Everything checks good. I checked PCM power wires while it was turning over it dropped to about 9.5 volts. I thought that was ok. Changed the injectors and it still won't run. it back fired through the intake a little. That was the extent of the excitement.
I am thinking it is mechanical now. I am still a little green to these motors. I just need a little input on what to look for.
Old 12-11-2011, 03:59 PM
nos487's Avatar
Maybe just start with the basics. Make sure it has good compression, fire and fuel. Have you pulled out the injectors and seen if they are spraying fuel?
Old 12-11-2011, 05:24 PM
91sonomast's Avatar
Do you have the correct reluctor wheel and tune in the PCM? Backfiring through intake sounds like a timing problem. If a cam was installed was it installed properly?
Old 12-11-2011, 09:52 PM
It is bone stock would the voltage drop with ign have anything to do with it? I was going to take the injector ran out of time. It's just going to make a mess. haha!
Old 12-12-2011, 01:27 AM
91sonomast's Avatar
9.5 is within acceptable GM limits for voltage drop on crank, anything less than 9volts is when GM says you could experience issues, so I wouldn't think that was it. Throw a battery charger on it, crank and check your voltage. It's possible it could be an issue, stranger things have happened.
Old 12-12-2011, 07:45 AM
LS1Tech Sponsor
psiconversion's Avatar
If you spray starter fluid in the throttle body will it start?
Do you have the correct tune in the car?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 12-12-2011, 09:19 AM
I tried spraying starter fluid in the throttle body and that's when it back fired. I got the wiring harness and the PCM form chevythunder.com. I assume that the tune is good I gave the guy all my specs. I think he has a pretty good rep. I hooked the PCM up to another car and it fired right up. I am pulling the engine this weekend. The guy I got the engine from had dropped it on the oil pan. The bottom of the pan was cracked to ****. I took the oil pan off and inspected everything. Everything looked ok but then again I didnt think about the The pick up on the CPS. I pulled the CPS out and it was good. Idk just pissing in the wind right know.
Old 12-12-2011, 09:59 AM
Adam123's Avatar
Check the keyed ign. wire to ecm. Lets computer know that when key is on.
Old 12-12-2011, 10:10 AM
Adam123's Avatar
On blue connector wire number 19 pink wire
Old 12-12-2011, 11:57 AM
LS1Tech Sponsor
Check the TPS voltage or % if you have a scanner.
Jon
PSI
__________________
Ebay Store
Old 12-12-2011, 01:01 PM
91sonomast's Avatar
Are you getting adequate fuel up there, correct?
Old 12-12-2011, 05:27 PM
Here is a thought. I don't have a MAF senser hooked up yet could that be the reason it will not run?
Old 12-12-2011, 05:30 PM
salemetro's Avatar
Entirely possible. I'd tie up all the loose ends FIRST, then try to fire it up. Much easier to diagnose that way.
Old 12-12-2011, 05:36 PM
aknovaman's Avatar
Yes, unless you have the PCM file set up for SD mode it will not start.
Old 12-12-2011, 05:58 PM
waterbug1999's Avatar
what does it do when u try to crank it over?
Old 12-12-2011, 07:09 PM
ad53030's Avatar
Can try to get a noid test light and make sure that the computer is sending a signal to the injector. That way you can rule out that the programming was done correctly. Can rent them at local auto parts stores. Just a thought. I had an issue that eventually turned out to be a programming error involving the VATS (depending on what year your 5.3 is).
Old 12-12-2011, 07:12 PM
The motor cranks over. It kinda sputters but does not run
Old 12-12-2011, 07:14 PM
I did the noid test it lit up
Old 12-12-2011, 07:26 PM
as in popping?
Old 12-12-2011, 07:27 PM
Goodies Speed Shop's Avatar
Can be a ground issue also... Motor grounded to frame?
Agree with salemetro about the MAF....
Quick Reply: 5.3 will not run part 2
