Need some help DBW to DBC swap, and choosing a harness for my 2009 5.3 swap
Im putting it into a 62 chevy pickup. What harness is the best bang for the buck. I have a stock harness with pcm but no pedal.
LS1Tech Sponsor
If I read correctly, are you planning on going drive by cable with a 2009 engine? If so, you will need to run the Lingenfelter box with a 411 style PCM from a 99-02 vehicle.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
To follow up on Gary's question, is there a reason you want to run DBC? A DBW pedal will be much cheaper than the lingenfelter box.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Andrew
On my Nova's build I used a C5 Corvette wiring harness (drive-by-wire) and ECM and modified the harness to be drive-by-cable for my 4150 style Accufab throttle body (had to add pigtails for IAC and TPS plus delete the TBW harness). Then I re-flashed the Corvette's ECM with the operating system from a 2002 F-body to make it drive-by-cable. You could do the same thing by re-flashing your ECM to a van or other cable throttle vehicle. HP Tuners does however require you to license both the original ECM and the "donor" ECM so even this option is not a freebie.
