Mast oil pan
Old 12-15-2011, 08:00 PM
69-chvl's Avatar
Default Mast oil pan
Anybody use one in a 68-72 A-body? How did you make out?
Old 12-15-2011, 09:30 PM
vandal699's Avatar
I am in for this inquiry also
Old 12-16-2011, 06:12 AM
67Skylark's Avatar
Watch lead time, I ordered one Nov26 from Pace $400 and just cancelled the order Wednesday after getting an update of backordered, should ship within one to four weeks. S&P had the modified F-body in stock.
Old 12-16-2011, 06:40 AM
69-chvl's Avatar
Geesh thanks - was going to order from them, thanks for the heads up. How about direct through Mast?
Old 12-16-2011, 09:00 AM
efs69's Avatar
I have one to install on an F body. Same conversion pan. Test fit was good for ground clearance and steering.
Old 12-16-2011, 03:42 PM
67Skylark's Avatar
That’s where Pace gets them and quoted the one to four weeks, not sure if anyone else carries them, I searched internet without much luck. I just happened to go to Mena to inspect an Aircraft and stopped at S&P, they gave me a tour of the shop, show me all their produces, Just very nice and knowable crew. It is spendy, $628.90 came with windage tray, bolts, cooler fitting, pickup tube, gasket and lokar dipstick. It looks to work better for the early a-bodys with the shallow front for tie rod cleance.
Old 12-16-2011, 05:47 PM
69-chvl's Avatar
Yeah I called Mast, out of stock till Jan!
Old 12-16-2011, 08:00 PM
borrone821's Avatar
Just go with an F-body pan. I've got that in my 69 GTO and with dirty dingo mounts, I had no problems whatsoever, and it sits about 1/2" above the framerail
Old 12-16-2011, 08:28 PM
Hal StClair's Avatar
I used the Holley pan on my 65 Olds, seems to be very close to the Mast pan.
Old 12-17-2011, 12:08 PM
Gray86hatch's Avatar
holley here going in the car tomorrow
ground clearance should not be a problem
Tim
