Truck harness in an A-body, ecm/fuse box location
Old 12-18-2011, 07:01 PM
hotrodolds's Avatar
Default Truck harness in an A-body, ecm/fuse box location
Where are you A body guys mounting the fuse box and ecm?
Looking for some ideas. 6 days from a 3 day engine swap thrash over christmas.
Old 12-18-2011, 09:50 PM
flywheel's Avatar
I have a 2003 lq4/4l80e set up in my 71 chevelle. I had speartech redo my harness and left it stock length. So I mounted my ecm on the drvrs side wheel well behind the headlite. The small fuse box that came with the harness I mounted on the fire wall above the mastercyl. Good luck.
Rick
Old 12-18-2011, 10:15 PM
SIKHS 5's Avatar
I used a S10 PCM mount . and mounted the PCM on the firewall (hidden in the drivers side quarter panel)
Old 12-18-2011, 10:37 PM
El S1 Camino's Avatar
If you are willing to extend a few wires and drill a hole, it can easily be mounted on top of the glove box. But since you are trying to do it quickly then this probably isn't the way to go. but i thought i would just throw it out there.
Old 12-20-2011, 01:48 AM
chuckd71's Avatar
Mine is on top of the glove box like above. Fuse box is in the glove box itself.
Old 12-20-2011, 05:21 AM
oldgoat69's Avatar
I have mine tucked in the space behind the driver side headlight, high on the inner fender. I used MSD vibration isolators as the mounts. They screw right into the PCM. The fuse block is adjacent to the PCM on the inner fender.
Attached Thumbnails Truck harness in an A-body, ecm/fuse box location-005.jpg
Old 12-20-2011, 06:22 AM
garys 68's Avatar
Drivers side fender in an S10 mount.
Old 12-20-2011, 06:53 AM
tango68ss's Avatar
..same for my TBSS LS2... Fabbed up a mount under the fender on the drivers side. Included my remote reservoir for the P/S
Old 12-20-2011, 11:40 AM
ponjohn's Avatar
Does everyone recommend getting the fuse block from the donor vehicle?
Old 12-20-2011, 05:24 PM
I went and bought individual 6 fuse fuse blocks and then used two of them mounted on the heater box. but i eliminated a lot from my harness, so this made more sense for me then to have a pile of empty spaces in the stock fuse panel.
See post 48 in my build
https://ls1tech.com/forums/conversio...3-build-3.html
Quick Reply: Truck harness in an A-body, ecm/fuse box location
