67 Camaro LS1 Rear Brakes
Old 01-01-2012, 02:43 PM
XedLos's Avatar
Default 67 Camaro LS1 Rear Brakes
So I want to put in Ls1 brakes on my 67 Camaro. What parts do I need from the dinar car in order to do this conversion. Do I need to buy a bracket or is this more of a direct Bolton swap.
Old 01-01-2012, 03:23 PM
Doug G's Avatar
I think you'll need everything from 2 right sides due to the shock set-up on 67's....
But here are a few ideas from what others have done...
NHBandit on Camaros.net
Sorry. Here a link to the rear calipers. They are a copy of a GM "metric" front caliper such as used on 80s Monte Carlo, Regal, etc and take a stock front pad. They fit great with the late 70s Trans Am 1" thick rear rotors but you need the adaptor brackets that are made for the smaller calipers. http://www.onedirt.com/news/new-prod...cing-calipers/ You want part # 120-6427 for a 1.25" thick rotor. On the front I have stock 69 Camaro disc brake rotors, dust shields and caliper brackets but went with Wilwood Aluminum large style GM calipers like these.. http://www.stockcarproducts.com/brakes8.htm on the front you want part # 120-5289 The front uses a stock 69-81 Camaro brake pad and the rear uses a slightly smaller stock 3rd gen Camaro, Malibu, Monte Carlo etc Front pad. I don't know what the going price is for the "kits" but I probably have aroud $600 invested in the whole setup including the rear brackets, new rotors, master cylinder & prop valve & the 4 calipers, maybe slightly more. This should be a great setup for normal street driving but is probably not suited for severe racing use.
Old 01-01-2012, 04:58 PM
XedLos's Avatar
I believe since I have a 67 it does not have stagered shocks. Would I still need 2 right sided brackets?
Old 01-01-2012, 05:17 PM
Doug G's Avatar
This may be more at what you need (I guess 68/69 needed the 2 rights...sorry
http://www.camaros.net/forums/showthread.php?t=161383
Old 01-03-2012, 12:41 AM
XedLos's Avatar
Would I need longer bolts for the rear or will the rotors and brackets leave enough length to put the wheel on.
Old 01-03-2012, 07:39 PM
Doug G's Avatar
Depends on rotor hat thickness and wheel combo.
Old 01-02-2016, 09:55 PM
camarodude87's Avatar
Correction. For a 69 you have staggered shocks. So you need 2 L/H backing plates and calipers. They didn't stagger shocks until 68. So you should need just a R/H and L/H backing plate with calipers. I know its a old thread just bumping for informational purposes
Old 01-02-2016, 11:21 PM
andrew69_04's Avatar
if your interested, i have 2 sets available for sale. just need new rotors and pads.
Old 01-03-2016, 10:15 AM
I have 2 L/h sets already Andrew. Thanks tho. Id post them on Protouring.com if I were you. Should sell quick there.
Old 01-16-2016, 01:25 PM
mecull's Avatar
Andrew, Do you have rear disc backing plates for 98-02 camaro for sale?
-Ron
Quick Reply: 67 Camaro LS1 Rear Brakes
