need some help, ls1 in mustang swap
little new to this site. this is my first LS1 swap also. i got a 1998 mustang gt the 4.6 in it was old and spun a bearing. So i picked up a LS1 out of a 2002 z28 camaro very cheap,(got it from a friend) and im going to use a T56 as my trans. and that is all I have. I just started this swap and was needing some help to find parts for the swap, a little info on what all i will need for the swap, I have nothing but the motor and trans. need pretty much everything, all wiring and computer, headers, motor mounts or easiest way to mount the motor,(new k-member or just different motor mounts). I think my biggest problem will be the wiring from the motor to my car. but any help would be great. if you need any more info just let me know.
Thanks.
Thanks.
LS1Tech Sponsor
You can go standalone on the wiring harness.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
AJE or UPR on the K member and trans cross member, 351 Foxbody Mac 1 3/4 long tube headers (modified by cutting off the ford flange and welding on a $40 set of jegs LS1 flanges) and a stand alone harness from PSI
you should be good to go
