VSS output to original speedo
Old 01-05-2012, 10:22 PM
PSI GUY's Avatar
Default VSS output to original speedo
Does anyone know if the VSS 4K output from the LSx ecu will operate the factory speedo in a 93 camaro, or will I need a signal modifier like the dakota digital box. I was hoping to not have to run a full set of standalone gauges as well.
Old 01-06-2012, 01:24 AM
LT1 Regal's Avatar
I'm pretty sure it will work without mods.
Old 01-06-2012, 04:32 AM
MontecarloDrag's Avatar
The stock speedometer needs a DC square wave, 4000 pulses per mile, so it will work good
Old 01-06-2012, 05:38 AM
PSI GUY's Avatar
Perfect, one less thing to have to buy, thanks.
Quick Reply: VSS output to original speedo
