g body wiring
g body wiring
i just recieved a 81 regal today and am starting to dismantle the engine compartment
wiring is the topic of this post
how do i take the 2001 truck 5.3 warness and intergrate it with the 1981 regal wiring harness to get it to power everything properly
pics, forum links, other referance items, i just am having a hard time tring to put this together and am drawing a blank
any help would be great
thanks in advance
dave
thanks in advance
dave
How much of the Regal "stuff" do you want to retain??
Dash? lighting? Key switch? Fuse panel?
I'm doing an 85 El Camel for a customer. I retained the ft body wiring, signals, h/ls, corner lights, etc, wipers, and the rear lites from the kick panel plug back. I also retained the stock column w/ turn, hi beam, horn, key sw.
The dash, a/c, radio, are custom.
I disconnected the thru the firewall connector, and traced all the wires and labelled them. Same thing w/ the rear body harness and the column harness. [I had printouts of the El Camel's wiring, and the American Autowire Hiway 22 panel I put in.] Makes things MUCH easier!
I used Weatherpak connectors at the firewall, and did away w/ the nasty stock connector. [You could use it and take out the unwanted wires.]
BEFORE YOU START CUTTING, GET THE WIRING DIAGRAMS!
If you need more ideas... It's best to call me..
706-342-3152
706-342-3152
i am planning on installing the engine harness
for right now i am going to run the stock dash but down the road i am going to switch to a f body dash
i deff will give you a call and i am tring to find diagrams right now
dave
dave
ttt for the weekend guys
i am getting real close to wiring this beast
i need to find out the wiring from the regal
i am having no luck in finding wiring diagrams
i am in need of some help please
thanks in advance
thanks in advance
Wiring diagrams
You may try this http://www.maliburacing.com/wiring.html i know that they are for the malibu, el camino, etc... But may still be the same because of GM color code per wiring.
Here is a link for the gauges pin outs, again they are for a Malibu but still may be the same not really sure though http://www.maliburacing.com/gauge_conversion.html
Tim.
Tim.
thanks guys for the help with the wiring
is their a pic of the bulkhead connector and pi location so i can hook up the wiring
someone had hacked the harness before me to put a v6 blazer set up in it
and i mean it was a hack job
I made a standalone out of the 03 truck harness and hooked it to my Chevelle hrness with 4 wires and batt cables. Didn't cut 1 wire from the Chevelle factory herness. I did use the old trans and dash. Was very easy and runs perfect.
