another 69 camaro oil pan question
my car is all tubbed and lowered in front , the chassis sets 3.5 inches off the groun , ive been searching for a oil pan but havent found anything that will work for me yet. the car will be turbo'd and see track and street time , so i need volume can someone point me in the right direction
depends on your budget, and which motor mounts you use......
super cheap, but not the best = modified truck pan
midrange$$ = 98-02 F-body pan unmodified, or slightly better CTSV pan( both need 1" setback mounts)
more dollars, and better = AutoKraft/Champ pan, Canton, Milodon
Best IMHO = Moroso, but its $300 including the pickup + plumbing for remote filter
I personally do NOT like either the Holley, Mast, RetroLS, or the GM muscle car pans, because they do not hold enough volume, and do not have good baffling for anything destined for the drag strip.
This is all just MY opinions, and you know what they say about those, haha
Barrett
Barrett
x2 for the Moroso. I just ordered mine. I bought the 20140 because it doesnt slope down like the 20141. I also bought a remote filter adapter from ebay for a VW bug. It was recommended by someone doing a swap. Im going to get -10AN to hose barb for the oil filter connection to save $.
i am going to run motor plates front and mid, do you know how far the moroso pan hangs below the crossmember in a "stock swap " on a 67-69 camaro or nova as the bottom of my crossmember is only 3.5 off ground
so im leaning towards the moroso pan for my build, how many are using this pan? i will be using moroso solid mounts, 350 style frame perches, manifolds flipped for turbo set up, am i on the right track with this pan? my car is super low thats why im being picky thanks for help
