Truck alternator not energizing via ECM
Old 01-14-2012, 10:22 PM
tiznodd's Avatar
Default Truck alternator not energizing via ECM
I know, another alternator thread... I did some searching and found enough info to get me where I'm at, but now I'm stumped.
The alternator is hooked up through the factory ECM (Blue/Green 2004 LQ4). The alternator was not working, so I tested the two wires going into the regulator and the green one has 12v, but the brown energizer wire has 0v. I wired the alternator manually using the resistor method and the alternator works fine.
I'd like to have the ECM control things rather than using the work-around method with the resistor. Any ideas why the ECM wouldn't put out a signal through the brown wire? Everything appears connected properly. Is there even an advantage to having the ECM control the alternator?
Thanks.
Old 01-14-2012, 11:36 PM
busta9876's Avatar
alternator should have two wires, gray and brown..not sure where you have a GREEN wire.
BROWN goes to Green PCM connector pin 15
GRAY goes to Green PCM connector pin 75
make sure those two are correct.
Old 01-15-2012, 09:24 AM
tiznodd's Avatar
I think it is gray actually. The flashlight I was using casts a blue light, so it probably looked green. I will double check the pins.
Quick Reply: Truck alternator not energizing via ECM
