What kind of power steering fitting is this?
I bought a 04-07 CTS-V power steering pump, and I cannot figure out what kind of fitting this is on the pressure outlet of the pump. The piece I am holding was screwed into a much larger black fitting on the pump. The dark ring that is closest to the camera is an o-ring. The dark C-shaped piece farther from the camera (and farther down inside of the fitting) is some sort of brass or copper-colored C-clip. I don't think it is meant to come out.
What kind of fitting is this? I feel like this should be pretty common, as it is offered as one of the GMPP accessory sets.
Also, what is that white stuff on the threads? I don't think it's teflon tape, and it's very hard so I don't think it's liquid pipe lube, but I could be wrong.
Last edited by FastKat; 01-19-2012 at 10:12 AM. Reason: LS1tech thumbnails not working
This pump is, for the most part, a Toyota pump. 1) It has "TOYODA" stamped on the front, and 2) The pump case is identical to the pumps used on the Corolla, Camry, Matrix, and other Toyota vehicles through the 2000's, except that some of those pumps have a pressure sensor on them.
Does that help any? I know nothing about Toyota pumps or their fittings.
