Oil Pressure HELP!
Old 01-19-2012, 03:27 PM
lsxhaley's Avatar
Default Oil Pressure HELP!
Got my LS1 into my S14. Finally got it running. Ran a mechanic gauge today behind the intake. Not getting no oil pressure. Took the gauge off and just left the tubing. The oil VERY slowly comes out the tube. I took my oil filter off & oil comes out very fast. I need help figuring out why oil is coming out soo slow & showing no pressure on gauge. Thanks.
Old 01-19-2012, 03:40 PM
yonerhottlt1's Avatar
Is it a new oil pump?! Did you correctly install the O-ring?!
Old 01-19-2012, 03:48 PM
lsxhaley's Avatar
I'm pretty sure I did. I'd have to take the whole engine out to check. It's a Sikky oil pan. Just trying to see the responses I get :/
Old 01-19-2012, 03:50 PM
lsxhaley's Avatar
& I know it's pumping bc it's spitting oil out the filter when I remove it & start the car. Just stuck here!
Old 01-19-2012, 04:12 PM
EHat911's Avatar
if it is an aftermarket pan with a filter relocation kit on it then try switching the hoses around on the relocation housing some of thoes pieces are directional and oil will only flow one way.. this has happened to a buddy of mine before
Old 01-19-2012, 04:34 PM
rotor vs. piston's Avatar
How sure are you that you have a good engine? Bearings could be past shot.
O-ring is what I'd most suspect if the engine is known good.
Old 01-19-2012, 04:38 PM
lsxhaley's Avatar
Next step is the oring. I have a feeling that might be my problem :/
Old 01-19-2012, 04:44 PM
lsxhaley's Avatar
The lines were backwards. You the man. Thanks soo much!
Old 01-19-2012, 08:59 PM
Old 01-19-2012, 09:45 PM
Glad you got it figured out. Any pics or vids?!
Old 01-19-2012, 10:13 PM
lsxhaley's Avatar
Ill post pics tomorrow. Tried to do videos, but it sounds horrible on playback bc no exhaust. Going get the exhaust done Saturday morning.
Old 02-02-2012, 07:58 PM
EHat911's Avatar
sorry for the late reply.. thought that may be the problem seen it happen acouple times! glad it worked out for ya
Quick Reply: Oil Pressure HELP!
