F-Body Oil Pan
Old 01-25-2012, 06:43 PM
mrarmyant's Avatar
Default F-Body Oil Pan
I purchased an fbody oil pan and pickup. I realize I still need a dipstick and tube. Is the windage tray different or am I an idiot? For the life of me I cant get the oil pan on my lm7.
Old 01-25-2012, 08:21 PM
FastKat's Avatar
I think the F-body windage tray is different in that it does not cover the two front cylinders - I guess it does not clear the front of the pan. Therefore, you are not an idiot.
Old 01-25-2012, 08:22 PM
bczee's Avatar
The F-Body Windage tray is 3/4 legnth... you can either buy one, or just cut it off just forward of the 2nd mounting point from the front. In the photo.. the F-Body is this mounted on the engine.. and the when being held is a CTS-V / Truck one. (note: I am hold it backward..)
Old 01-25-2012, 08:57 PM
Beyond Static's Avatar
Cut the front off the LM7 tray as bczee said. That's how mine is done and no interference
Old 04-15-2012, 06:38 PM
R. Finkle's Avatar
I'm using the fbody pickup tube and the tray mount won't fit. I'll have to cut a hole with a dremel.... so it won't DIRECTLY mount up, but it isn't hard to make it work.
Quick Reply: F-Body Oil Pan
