Stainless Works LS Swap Headers
Hi Guys
Just in case you didn't realize, we carry a full line of LS Swap headers for many Chevy muscle cars!
Who is using our stuff? Post up some pictures of your current projects for us to see! Make sure you tell us what year and what swap kit/motor mounts you used!
Generally we are pretty close to the components since there isn't a huge amount of room around the box. HOWEVER, the motor mounts that you use can play a huge difference. We are currently compiling a list of motor mounts and swap kits that we know will work best with our headers.
Not be negative here but I tried to help you guys with your headers and you wanted to charge me $3k for a set of custom headers. This was before I found out that the set I got were defective anyway. I am using the BRP mounts for a first gen and the headers are not even close. Ironically enough it looks like your older headers for your Art Morrison suspensions would have fit but after a lot of time trying to help you guys out it was obvious that you were not interested in helping. Here is the link.
https://ls1tech.com/forums/conversio...ality-fit.html
I have a 1968 camaro ,here are pics!!the headers almost hit on two spots!!
Here is the link to the build of my car!!
https://ls1tech.com/forums/showthrea...hlight=Bmf5150
What car do you have? Post some pictures for us, absolutely!
1 Post
Yeah, GREAT. So you're basically cluttering up this forum with a topic that doesn't actually have any worthwhile technical content, just a ridiculously transparent (& lame) attempt at marketing/getting the company name out there... Sorry guys, but...
Weld problems aside, your fitment issues were not our fault. We know our headers work with the Street and Performance kit, and while they may work with other mounts, we cannot guarantee fit unless you are using what we recommend. There are just too many variables. Our headers are not guaranteed to work with a BRP mount kit. BRP even make their own headers that go with that swap, so there's no market for us to make sure our headers fit their kit. I'm sorry things didn't work out, but we didn't design the headers to use the swap setup you chose, so i don't feel you can blame us if they don't fit.
We are pretty close to that box but it looks like we aren't hitting it. I know you are using the Street & Performance kit, do you have it in the neutral position?
We do. And we just finished R&D on a new set that lets you use the stock steering box.
Keep in mind we pay to be allowed to advertise.
To be honest, we are generally a little less expensive than they are on everything.
I expected to see some venting about header fitment but please understand that there are so many different combinations from mounts, fittings, steering boxes, and even tweaked subframes, that I cannot guarantee my headers will fit unless you call or email us with the details of your swap.
Unfortunately, I have to say No to people almost as often as I can tell them the headers will work. If you don't check with me, you've simply got to hope you get lucky. Giving me all the details can save a lot of headaches
We've been begging Bruce for 1 7/8 for a while, but he's been non-responsive. I suspect that he gets bombarded with so many requests for products that would ultimately never sell that he's reluctant to take on something new. I emailed SW a few months ago asking if they would build me a set that I could buy through them or Hawks, and never received a response.
Aside from the defect you state what has changed in from SW's quality and manufacturing from 4 years ago? As for your recommended setup with the variables I gave SW enough information that would have worked for the S&P along with the BRP setup and pretty much everything inbetween. I have a set of Kooks TBSS headers and they would fit a S&P mount setup also they ended up costing me less overall also than I originally paid for the SW's. SW never stated that they only fit the S&P setup even after I contacted you multiple times. Also note there is not one bit of information on your website currently about them fitting only for S&P mounts. It is very clear to me when you guys setup those headers you did it on a car with a rack and pinion steering which is why they are so close to the steering box that everybody that uses the headers has to dimple them. It is also the same reason why they are close to the idler arm on the other side and hit with the BRP location. When I contacted Kooks they were willing to bend over backwards to get me a set of headers. They even offered to let me have a set unwelded so I could tack them and send them back for final welding and fitment at no extra charge. If you don't believe me do a search on the site for your headers and look at how many people are dimpling your headers so they clear the steering box. You call that a good fit?
We believe you.
We have made our mistakes and we've learned from our experiences so that we can grown as a company. I guess it's neither here nor there but things that happened 4 years ago are in no way representative of how things are today.
Sorry it didn't work out.
Is the general concensus that the S&P stock location mounts are the best mounts to use in conjunction with your ls swap headers for a first Gen Camaro/Third Gen Nova? I have a set of the #CALS1SB headers right now and just want to get the info straight from the source, Thanks-
