Harvesting Harness Wire and I need help identifying connectors
Like the tile says I am harvesting some of the unused wire out of and a 2008 TBSS harness. I am removing any connectors and associated wiring not needed for a standalone harness. I need help identifying a few connectors.
1. I believe this is a rear O2 sensor plug, but I am not sure as there is only one. The plug on the passenger side was tore off when the motor/trans was pulled.
2. I labelled this one, but the writing is not legible now. I blieve it may go to the truck intake I removed. It is near the rear passenger side cylinder head.
3. The purple connector on the left, which is near the fuseblock connector?? on the driverside.
4. I can't read the entire label on this one, but what is legible says "Fuel rail drive side". I am pretty confident this one is not needed.
5. Located at the rear of the engine immediately after the engine oil pressure switch.
6. I know I don't need this one, but what is it?
Sorry I rechecked #2 and it is for the map sensor. The #3 you initially said was near the fuse block. Is the fuse block located at the rear of this engine? If so did this vehicle have a separate transimssion controller?
