G Body Swap Crossmember Question
Old 02-22-2012, 10:22 AM
RIP1976's Avatar
Default G Body Swap Crossmember Question
Need some help I'm gonna be using a new style truck 4L60E with removable bellhousing. Has anyone used this an is the mounting length the same as a 700R? I planned on using a Jegs double hump crossmember part number 41051 if I can.
Old 02-22-2012, 12:36 PM
01cherryreds10's Avatar
I beleive they are the same crossmember
Old 02-22-2012, 04:50 PM
the_merv's Avatar
I know they are close..
Old 02-22-2012, 09:02 PM
Yep they are the same
http://www.transmissioncenter.net/gf...ers_.htm#700r4
Old 02-23-2012, 12:55 AM
Verz's Avatar
Good to know for that price
Old 02-23-2012, 01:23 AM
RIP1976's Avatar
Now if I can't find out if I can use standard location motor mounts with bpr headers.
I started a project like this a few years back with a LS2 from a GTO an using a set of EDL6701 mounts the motor an the GTO coils fit perfect!
How much room I had behind the passanger side coil
Old 02-23-2012, 01:26 AM
Verz's Avatar
Merv was able to use stock loction mounts and the brp headers, not sure I like how the collector currently are on the brp headers though
Old 02-23-2012, 01:38 AM
RIP1976's Avatar
Good deal I was thinking merv used the actual brp ones an heard they moved the motor back. I'll be ordering the mounts now from eBay an order the headers tomorrow. I agree I don't like the slip collector but I don't wanna waste $300 on a set of f bodies an them not fit
Old 02-23-2012, 02:04 AM
the_merv's Avatar
Yup I used the normal SBC-> Ls Conversion Plates, Mounts in stock locaton on the Cradle, stock Clamshells.
Here is a pic..
I have the 1 78", 3" Collector BRP Longtube Hedders, there are a couple spots where they are close, but they clear. I installed both Hedders from the bottom, took about 3 min per side.
Old 02-23-2012, 02:27 AM
RIP1976's Avatar
Hey Merv did you use a actual AC Delco fuel fiter or did you go with a cheaper version? Oreilly offers 3 different ones from $20 for a Microguard, $46 for a Wix or $112 for the AC Delco
Old 02-23-2012, 11:55 AM
the_merv's Avatar
I have the AC Delco on my car, the S10 I used the Wix. No issues with either.
Quick Reply: G Body Swap Crossmember Question
