6l80e trans what shifter to use
Old 02-22-2012, 04:33 PM
96ImpalaLT1's Avatar
Default 6l80e trans what shifter to use
I have a 93 mustang that I am working on and I am going to swap a ls3 in it I am also going to throw a 6l80e trans, I'm having a hard time trying to find a shifter for it, I know the new corvettes and new camaros use that 6 speed aut trans but can't find a used shifter, I heard that the g6 uses the same trans?? and can be used??
Old 02-23-2012, 07:56 AM
LS1Tech Sponsor
psiconversion's Avatar
G8 Shifter would probably work, but remember the paddle shift wiring is different between the truck, G8 and Corvette.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 02-23-2012, 11:18 PM
Bo185's Avatar
Any regular cable auto shifter will work. You just will not have TUTD function. This can be made to work as well with just a switch mounted anywhere. Or just use a factor shifter like mentioned.
Another option you can use the CTS-V auto shifter it has TUTD function on it as well.
Old 02-24-2012, 09:52 AM
LS1Tech Sponsor
Trick Performance makes the paddle shifter as well if you want the TUTD.
Jon
PSI
__________________
Ebay Store
Old 02-24-2012, 02:36 PM
bsharpe's Avatar
What are the details on trick performance paddle shifters. I could not find any information on them.
Quick Reply: 6l80e trans what shifter to use
