Body wiring harness options on a swap?
So i'm getting close to getting my fox project running and one thing i've been dreading is the body wiring harness. I have a PSI engine harness coming for the motor and thats a cakewalk compared to the mess i have under my dash.
I dont need all this BS and all i really want to run are the basics for a street car (horn, cig lighter, radio ignition, fan, heat, dome light, brakes, wipers,hazard, headlights, turn signals)
I'm not using the fox gauges since i'm going with all pod gauges made into a plate going in the stock location
Has anyone had any experience with a motor swap and what i'm going through? I found a website that deals with this but i dont know if theres an easier way than this or if anyone had any experience with them.
http://www.ezwiring.com/wiring_harness.html
thanks!
thanks!
I just went through my body harness the same way I did my engine harness. Removed all the un-necessary stuff and kept the good, and added some relays. Also it is your chance to add things like bottle heaters, and other accessories. The thing about harnesses from some places is you don't get the oem connectors to things like the headlights, switches, and all that good stuff, that's why I kept the oem harness.
i just went through my body harness the same way i did my engine harness. Removed all the un-necessary stuff and kept the good, and added some relays. Also it is your chance to add things like bottle heaters, and other accessories. The thing about harnesses from some places is you don't get the oem connectors to things like the headlights, switches, and all that good stuff, that's why i kept the oem harness.
