Trans Dapt motor mount
Ok, I bought the 1" set back kit and it comes with the old style motor mounts along with the adapter plates. I have the newer style clam mounts so they are wider and can not be used together. I used my clam mounts and got it to go in but, after looking at it for a few days I would like the engine to sit lower. What mounts could I use on frame side to go with the mounts that came in the kit? Is there something that will work or am I better off fabricating my own?
I used these with moroso mounts on my 82 trans am. I hate the cheap trans dapt plates. I used some more expensive plates off ebay on an 82 vette and those were much better. I needed to trim the block because I had already had the TD plates zinc plated but otherwise the plates would need trimming. The support nuts are a joke, they only fit in 1 location and the supplied bolts are too long for solid mounts. Also, the threaded hole locations are not perfect, I had to drill out my moroso mounts. I have these moroso mounts on all my cars, I swear by them and they have always worked perfectly, fit like a glove every time...not now
The engine sits super low however so maybe...the moroso mounts are a solution for you....if you want solids that is.
odd, I've used the trans dapt plates in probably 7-8 different GM ls1 swap projects and have never had any issues with them. I recommend them to anyone doing a swap. I've had to do some trimming to get them to fit at times, but very minor amounts.
Did you use the "support" nuts?
See where it hits that square machined block on the right? I think that section is used for the machining track system @ the factory...anyway, there's a bunch of interference there. Not something that isn't easily remedied but the others I used didn't have this issue
Ok, so your saying the mounts they come with are garbage? What are my options? I see your set up, I am putting this in a g body car and want the engine to sit a little lower. If I went with the mount style pictured what are they for? I dont want all solid mounts.
The solid mounts are the moroso mounts, those are not garbage. I never had a problem with them ever before.
I;m using upper moroso solid mounts, the lower is a BMR K member with poly inserts. If you buy the complete moroso kit it has solid bottom plates but you could modify them or build some your own and use poly bushings.
