5.3 jeep cj manifolds?
Old 03-02-2012, 12:51 AM
rynestone's Avatar
Default 5.3 jeep cj manifolds?
Im putting a 5.3l into a jeep cj5. I have just about finished my project, but my stock truck manifolds wont fit... Can anyone tell me which manifolds I need to find that will be a block hug fit?? not wanting to use headers
Old 03-02-2012, 01:16 AM
SIKHS 5's Avatar
do both sides not clear? or just one?
my the chevelle i was able to use a LQ4 Manifold on the Passengers Side but had to use a LS1 F-Body Manifold on the Drivers Side.
there are alot of posts regarding manifolds/clearance, should be alot of options out there for you if you run a general search.
Old 03-02-2012, 01:23 AM
welldonecj7's Avatar
Some have used stock manifold but if your set up doesn't allow use I know c5 and c6 Corvette hug close. Another that some have used is a fbody set up.
Old 03-02-2012, 01:26 AM
SIKHS 5's Avatar
yeah^^
corvette c5, c6 z06, or the trailblazer ss manifold route.
Old 03-08-2012, 08:43 PM
Haggar's Avatar
I used sanderson block huggers in my CJ8, but check out 2010+ camaro manifolds, they look to be pretty good for the CJ.
Old 03-08-2012, 09:38 PM
rock-rod's Avatar
LS3 manifolds might work for you if the motor is set high enough.
Quick Reply: 5.3 jeep cj manifolds?
