E-38 ECM and LY6 people
I'll start by saying thanks for any input that anyone gives to this thread.
I'm running an LY6 with a modified harness with the E38 ECM. I cannot get a tach signal from it? Everything is set correctly with HP tuners in the program and I think I have the correct pin from the ECM connected? The motor is in a 1992 Camaro, I'm using the factory tach, I've tried an aftermarket one as well.
Once again thanks for any help.
LS1Tech Sponsor
Did you set HP Tuners to read 'Crank' and the hi and low to 15? What Tachometer are you using?
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
LS1Tech Sponsor
Black connector pin 48.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
