ls1 harness problems
im installing a ls3 into my lt1 bird using a ls1 harness. im trying to change the pins on my lt1 harness under the dash to match the ls1 harness under the hood. is these possible i need help services or good guide to follow
There is a tool to remove the pins and place them where they are needed to be. It's not that simple, there are some wires and connectors that have to be moved in the Harnesses aswell.
I've swapped several cars and built a few harnesses..the tools help..make them look clean.
Look at this here..
https://ls1tech.com/forums/conversio...on-sticky.html
The LS3 is a little different cause it's a GEN IV 58X Engine, you will have to account for that.
