1972 Nova / truck manifolds?
Old 03-06-2012, 07:15 PM
9 Second Truck Club
stock48's Avatar
Default 1972 Nova / truck manifolds?
I tried the search and every car that came up had headers. I have a 72 nova and wondering if the drivers side truck exh manifold will clear a manual style gear box. Any info appreciated!
Old 03-06-2012, 07:25 PM
99VetteFRC's Avatar
I saw a thread in here somewhere, CTS-V manifolds are very tight. U can also cut the huge flange off the manifold and weld a V-Band flange to it. I did and it worked great. Maybe a V-Band will give you the clearance you need. They also weld VERY easy with a MIG and you don't have to heat the cast.
Attached Thumbnails 1972 Nova / truck manifolds?-dscn1128.jpg   1972 Nova / truck manifolds?-dscn1129.jpg   1972 Nova / truck manifolds?-dscn1130.jpg   1972 Nova / truck manifolds?-dscn1131.jpg
Old 03-06-2012, 07:27 PM
Kansas_Nova's Avatar
My truck manifolds did not clear the steering box, i used the standard mounts (no set back) but i also had to shim up the mounts for the oil pan to clear the subframe. I ended up gong with some F-body manifolds I picked up for like 20 dollars and they cleared just fine for me.
Old 03-07-2012, 12:20 AM
9 Second Truck Club
stock48's Avatar
Thanks for the info guys. Reason I want to run the truck manifold on drivers side is Im running a truck turbo kit. I was thinking same thing on the v band. What's holding me up is I have to cut the mounts off for the rack to get a gearbox in there. To run the rack I have to buy a $1050 set of TRZ control arms.
Old 03-17-2012, 10:53 PM
5.3Lnova's Avatar
i used truck manifold on my 69 nova they fit with the proper engine placement and manual box. i did shave a little off the manifold though.
robert
Quick Reply: 1972 Nova / truck manifolds?
