How do you remove a LS1 water pump pulley?
Old 03-06-2012, 09:40 PM
74ventura's Avatar
Default How do you remove a LS1 water pump pulley?
Im winding down on my LS1 swap into my nova and have ran into yet another problem, the truck water pump inlet is going to hit the intake tube. I have a pump off of a Camaro and someone recommended swapping the truck pulley to it and use the camaro pump because the inlet is on the front.
My question is how to get the water pump pulley off?? I tried the Harbor Freight 3 jaw puller, but it shattered while attempting to take it off. I tried to apply heat to it as I was taking it off too.
Any suggestions??
Thanks
Old 03-06-2012, 10:16 PM
thenova70ss's Avatar
Any suggestions??
Thanks
I dont think it comes off. But you might try putting it in a press.
Old 03-06-2012, 11:41 PM
bczee's Avatar
What front Accessories do you have ?.. you stated LS1.?... do you have an Truck block and front accessories and now putting an LS1 intake on it ?.. what do you have LQ4/9, LM4/7, etc ? or do you really have an LS1 ?
I would try another pump. I think there was some other threads on the 10' F-Body pump fitting around car TB. Or some other of the newer engines.
Old 03-06-2012, 11:45 PM
the_merv's Avatar
You arent going to get it off.
What accessories are you using?
Old 03-07-2012, 12:54 AM
garys 68's Avatar
You just need a 3 jaw puller to get the truck pulley off. To remove the f body pulley you also need to cut the pulley up to the shaft. Or you could set up a jig to press it off. I've done 3 swaps and never got the f body pully off without destroying it.
Btw heating it can destroy the seals.
To press a new one on, you need to remove the rear cover and support the rear shaft with a small socket. Otherwise you'll just press the shaft through.
Old 03-07-2012, 01:21 AM
the_merv's Avatar
Or just get a Water Pump that will fit what he is doing..if you need a Truck Pump use the '06-up one....
Old 03-07-2012, 01:39 AM
garys 68's Avatar
If you need to swap out a truck for an LS1 intake for hood clearance, the L92 water pump will clear an 07+ DBW TB. It will not clear a earlier DBW TBs.
You could use an f body with spacers but that would mess up aftermaket AC bracket mounting (Kwik). Same issue with 2010 camaro L99 WP.
Swapping pulleys also allows you to keep a mechanical fan.
Truck spacing, f body pump with truck pulley, Kwik bracket.
Another with a mechanical fan.
Old 03-07-2012, 01:50 AM
garys 68's Avatar
Another option, see post 56.
https://ls1tech.com/forums/conversio...ap-pics-3.html
Old 03-07-2012, 09:41 AM
74ventura's Avatar
Allright, thanks for the help, a few different options I have here to go with.
BTW, im running a '03 I believe LQ9. Im running the stock truck accessories (Just ALT) and have converted the TB to DBC.
Old 03-07-2012, 10:20 AM
garys 68's Avatar
In your case an 07+ L92 water pump will clear the DBC. It has the outlet angled at about 45 degrees off the top of the pump.
It would not clear the DBW TB with traction control.
Here's a pic of a 5.3 with the L92 water pump. This is also how I discovered it wouldn't clear the pre-07 DBW TB.
Old 03-09-2012, 08:46 PM
74ventura's Avatar
Ok, thanks for the input. Just incase anyone reads this thread for research, I was able to do the pulley swap from the truck pump to the F body pump. As many have said, the F body pump is a PITA to get off or is not meant to come off. I took a 2 jaw puller and put a lot of pressure on it, then took an oxy/acetylene torch to heat it and it only moved a quarter inch. I figured since I heated the pump up, the seals were shot, so I proceeded to just cut the pulley off to see if there was any reason it wouldn't come off, but I guess it is just pressed on that tight or corrosion seized them together. After cutting the pulley off, I realized the housing was still good from the F body pump so I decided to take the guts out of the Truck pump and put em in the F body housing. The trick to swapping these pulleys is to use a press. I pressed the truck pump out through the back of the housing and pressed it into the F body pump housing. The press made it easy. Hope this helps.
Old 03-09-2012, 09:50 PM
sscamaro1384's Avatar
i took my fbody pump to a guy here locally. He drilled two holes in the f body pulley and was able to use a puller to safely pull it off. then he used a press to fit the truck pulley on
Old 03-10-2012, 06:26 PM
oldgoat69's Avatar
Just a thought, look at impeller to housing clearance. Too much clearance can cause cavitation and aeration of the coolant resulting in overheating and air pockets in the cooling system. This is a common problem in Pontiac and Chrysler engines. If you have a stock untouched pump look at the impeller to back plate clearance and adjust accordingly.
Old 12-27-2013, 04:40 PM
Indianadroprop's Avatar
I know it's an old topic but could I drill holes into the pulley and tap them to use a steering wheel remover to get it off?
Old 12-27-2013, 09:38 PM
garys 68's Avatar
Worst that could happen is you wreck the pulley......
Or my guess, the cast aluminum steering wheel puller breaks.
Old 12-28-2013, 06:23 PM
Lsx Rubi's Avatar
So if I were to use a gen3 lq4 block with truck accessories, with l92 heads and ls3 intake and ls3 throttle body would the l92 water pump work for my application.Thanks
Old 12-31-2013, 11:52 AM
Lsx Rubi's Avatar
Anyone?
Old 12-31-2013, 01:28 PM
LS1Tech Sponsor
hellbents10's Avatar
First thing that came to mind for me was to put a supercharger on it lol. I have seen them come off in no time with a 8-rib setup and a good tensioner.
Old 01-04-2014, 12:09 PM
Pocket's Avatar
Why not space out the car WP with some 3/4" stock?
Old 01-04-2014, 02:37 PM
garys 68's Avatar
That works but the Kwik bracket I had mounts to the water pump. I couldn't have used it without mods if I used spacers. That also eliminates using the L99 Camaro pump.
Also, note the pic above. I wanted a mechanical fan. Cant do that without the truck pulley.
Quick Reply: How do you remove a LS1 water pump pulley?
