Fuel supply issue 67 camaro ls1 motor
Old 03-08-2012, 10:48 AM
96t/acj's Avatar
Default Fuel supply issue 67 camaro ls1 motor
hello,
Im having issues getting fuel to the fuel rail...
I have factory tank to airtex e2000 pump to corvette filer to fuel rail....
if i remove the filter i get gas coming out of pump and i hear the pump working so i know thats fine. Its a wix filter so i also know that it should be good. (everything is brand new)
HELP!
Old 03-08-2012, 10:56 AM
RPM Graphics's Avatar
make sure you have the outlet & the return lines in the right place. i've seen people hook them up backwards before.
Old 03-08-2012, 11:24 AM
96t/acj's Avatar
ok so the outlet was easy cause it says outlet.... But seaching this site i see people connect the return and inlet at two different locations... My return is the outside line and the inlet is the one inline with the outlet.
Sound correct?
Old 03-08-2012, 11:40 AM
sorry, i meant inlet & return & no, you have it backwards. the return is the middle line even with the outlet & the inlet is the outer line.
like this,
Old 03-08-2012, 12:15 PM
96t/acj's Avatar
ok so the good news is im hooked to the return, i hope i didnt mess anything up...... thanks soooo much for your help!!!!!
Quick Reply: Fuel supply issue 67 camaro ls1 motor
