Source for old wiring connectors
Old 03-12-2012, 08:24 AM
garys 68's Avatar
Default Source for old wiring connectors
I've got a reverse light switch for an 82 Super T10 that threads into the tailhousing. I need the electrical connector pigtail to hook to it.
It's clearly larger than the type of connectors used on the LSx motors.
Anyone know of a source for these old GM connector pigtails?
Old 03-12-2012, 08:46 AM
LS1Tech Sponsor
psiconversion's Avatar
Looks like a weather pack. Will PM you if I can find something.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-12-2012, 08:47 AM
Twin_Turbo's Avatar
Typical weatherpack connectors. You can buy them from summit they list all the caspers electronics stuff.For a wider assortment of weatherpack and metripack stuff go to white products
Old 03-12-2012, 09:20 AM
garys 68's Avatar
The plug looks larger than the typical weather pak connectors.
I'll pick one up today and see if it fits.
Old 03-12-2012, 09:55 AM
bczee's Avatar
I usually go to Current Performance, EFIConnection, Mouser, M&H and Casper Electronics. Many Automotive parts stores (not O'Reilly's or Autozone type of stores, but a good old time parts store).. will have catalogs for Electrical Connectors and pigtails.. Try Napa also.
Might also check on the 3rd Gen F-Body sites..
BC
Old 03-16-2012, 01:50 AM
garys 68's Avatar
It was a larger weatherpack connector. Thanks.
Old 03-16-2012, 09:33 AM
bczee's Avatar
Yeah. I don't think GM was that much into the newer connectors then.
Might try the local Pick n Pull. Maybe Car-Parts.com and see if you can find one that has a car or starter for those years.. and see if they can pull the connector.
good hunting !
BC
Quick Reply: Source for old wiring connectors
