LM7 intake swap
Old 03-21-2012, 10:06 PM
72_elcaminoman's Avatar
Default LM7 intake swap
Want intake can i install on my LM7 engine. The truck one has alot of holes that i think need to be sealed if not using Emissions. I also would like some help with what to do with this hole if im going to use the factory exhaust manifolds.
Old 03-21-2012, 10:16 PM
cant get my pictures to post...
Old 03-22-2012, 06:59 AM
LM7Mustang's Avatar
Well are you wanting to go to a car intake?
Depends on what your goals are. You can run an ls6 intake. Get rid of all the emmissions. (Close the coolant xover through the throttle body).
However you'll have to swap over fuel rails, injectors, change wiring clips, change your wp for the car style where the outlet goes out through the front opposed to through the top, then change your radiator hose. I just luckily found a friend who is going carb and got all that for a good price and it was easy. But if you have to peice it together it makes you think twice if it's worth it because the truck intake flows pretty well.
Old 03-22-2012, 08:32 AM
well i had some pics to post because im not sure how to block of these holes. I want to say one is the EGR value which i know i will not be using. i know they sell a plug for that now. the other is on the top of the intake were the vortec over goes one. also i had three fuel lines. one for pressure, one for return and the other when up to the top of the intake in a value what is that used for and do i need it...
Old 03-23-2012, 10:59 PM
anyone have an idea what to do
Old 03-24-2012, 01:18 AM
i r teh noobz's Avatar
3 fuel lines? I'd assume the third one is either the vacuum supply to the pressure regulator or the EVAP hose. You need the vacuum line if you keep a return-style rail. EVAP monitoring can be removed from the PCM.
Old 03-24-2012, 07:10 AM
garys 68's Avatar
The car intake is going to have pretty much the same ports, EGR, brake booster, purge solenoid, 2 PCV ports, etc.
Get the plug for the EGR and you can get rubber caps for most of the others. Anything else, you can tap and plug.
Old 03-24-2012, 09:58 AM
My old LS1 intake had an expandable pipe plug from the hardware store in it. Wasn't pretty, but I ran that intake for about 6 months before finding an LS6.
Old 03-24-2012, 10:19 AM
99VetteFRC's Avatar
Look at the thread for "Smoothed Truck Intakes". There are a lot of good ideas there. I have started smoothing my extra truck intake. I think I'm gonna cut all the bungs off and fiberglass the top of the intake like others in the thread.
Attached Thumbnails LM7 intake swap-dscn1215.jpg   LM7 intake swap-dscn1217.jpg   LM7 intake swap-dscn1224.jpg   LM7 intake swap-dscn1225.jpg
Old 03-24-2012, 04:36 PM
so what is this in the red box of pic and do i need to use it. If not how to plug it. Also anyone have and idea were to get a cts-v oil pan. been looking and need to buy one ASAP
Old 03-24-2012, 07:20 PM
99VetteFRC's Avatar
That is the purge solenoid. Don't need it. I haven't quite figured out how to block it off yet. As for the oil pan, I bought my CTS-V LSA oil pan off Ebay for $190+ shipping and it came with dipstick, windage and gasket. No bolts though. I reused the truck pan bolts although the CTS-V pan didn't use one on the passenger side.
Attached Thumbnails LM7 intake swap-dscn1184.jpg   LM7 intake swap-dscn1185.jpg   LM7 intake swap-dscn1186.jpg   LM7 intake swap-dscn1188.jpg   LM7 intake swap-dscn1189.jpg
Old 03-24-2012, 07:54 PM
so how did you fill that hole once you removed it from intake. Guess i will keep looking i have posting out there to find one.
Old 03-24-2012, 08:02 PM
99VetteFRC's Avatar
I haven't yet. Although I did find the a 12mm bolt fits in the hole nicely. I think I'm gonna drop a short bolt on the hole and then fill the entire cavity there with fiberglass filler and sand it smooth. I just haven't got that far yet. Been busy and haven't made anyfurther progress since the pics.
Old 03-24-2012, 08:29 PM
ok cool. keep me posted. Im heading out of town for business for a week. no working on mine for a week.
Old 03-24-2012, 08:34 PM
99VetteFRC's Avatar
I gotta wait till next friday when I get paid to but Tiger Hair.
Old 07-25-2013, 09:12 PM
Crawl's Avatar
Any update?
Old 07-26-2013, 06:21 AM
ijimmy's Avatar
1st choice ls6 , second ls1 , get the bolts and rails and injectors also
Quick Reply: LM7 intake swap
