gto intake on lq4 w/truck FEAD?
Hey all
So it fired up! (lq4 in Grand Wagoneer) Got a silverado fusebox to replace my busted one and with a little re-wiring the express harness got things crankin. Fired her up at 1 am. I've got some good neighbors!
I did have to run it on intake cleaner cause my injectors were crazy clogged even though I filled the fuel rails with seafoam since thanksgiving. Took them out and the soaked them in cleaner and it turned black. Then clicked them with some pressurized cleaner until they sprayed clean. One injector is dead.....no clicky.
Anywho.
I need an itake that goes to the driver's side. I'm thinking the gto setup might be good. Can i use a truck throttle body and MAF? Thanks
Anywho.
LS1Tech Sponsor
Drive by wire or cable?
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
https://ls1tech.com/forums/generatio...ttle-body.html
they apparently are the similar if not the same. Time to go for the gold.
