More fan wiring questions
I have a dumb fan wiring question. I wired the temp sender directly to my gauges. Should I wire it through the pcm so the fans can turn on? I assume there has to be a signal from the temp gauge. Can I splice off the the sending wire from the sensor? If so, how to I connect it through the pcm? I had my harness modified, but do not see a temp wire. Thanks. BTW it's a ls1/t56 in a 67 Chevelle.
