coolant temp sensor adapter fitting for passenger side head - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 04-05-2012, 04:25 PM   #1
Default coolant temp sensor adapter fitting for passenger side head
rich l has showed me a diff fitting might go with that one
all juiced up is offline   Reply With Quote
Old 04-05-2012, 04:56 PM   #2
ZQ8LS1's Avatar
What size to what size ??
ZQ8LS1 is offline   Reply With Quote
Old 04-05-2012, 05:27 PM   #3
LS1PUNK's Avatar
Im in as long as they are what u say they are.
LS1PUNK is offline   Reply With Quote
Old 04-05-2012, 05:47 PM   #4
Can you assure us they're better than the ones that twist and break before they're adequately tight? I went through two such fittings even knowing of their tendancy to break.
Andy1
Andy1 is offline   Reply With Quote
Old 04-05-2012, 06:01 PM   #5
andy1 i will look in to that issue
Old 04-05-2012, 06:04 PM   #6
zq8ls1- i will double check but i think its 12mm to whatever an aftermarket auto meter sender is
Old 04-05-2012, 06:11 PM   #7
Threads are 12mm-1.5. This is the adaptert I used for my 1/8" NPT SPA temperature sending unit.
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
The note there to "drill out the I.D. of the adapter to accept your sender" was necessary and worked well.
Rich
Rich L. is offline   Reply With Quote
Old 04-05-2012, 06:16 PM   #8
nice rich had a hard time locating these but you still have to drill and tap the inside
Old 04-05-2012, 06:53 PM   #9
chuckd71's Avatar
You don't tap the inside do you? Don't you just open the lumen enough for the sender tip to stick through?
chuckd71 is offline   Reply With Quote
Old 04-05-2012, 08:44 PM   #10
rickyzZ28's Avatar
Quote:
Originally Posted by Rich L. View Post
Threads are 16mm-1.5. This is the adaptert I used for my 1/8" NPT SPA temperature sending unit.
Rich
I think the threads are 12mmx1.5 but I could be mistaken. Here is the adapter that I used.
rickyzZ28 is offline   Reply With Quote
Old 04-05-2012, 09:22 PM   #11
LS1MCSS's Avatar
Quote:
They are 12MM. I have cut a lot of senders down on my lathe and re-threaded for people.
LS1MCSS is offline   Reply With Quote
Old 04-05-2012, 10:24 PM   #12
ZQ8LS1's Avatar
I have a switch with 3/8 NPT...does anybody make a adapter for that ??
While we are on the subject...I know the coolant sensor goes in the drivers side front head,what goes in the passenger side rear head ?? A plug ??
I got my heads used & building a motor from scratch & what is the hole next to the cooling hole for ??
Old 04-05-2012, 10:42 PM   #13
99VetteFRC's Avatar
Drilled and tapped mine for old school mechanical guage.
coolant temp sensor adapter fitting for passenger side head-temp-sensor.jpg   coolant temp sensor adapter fitting for passenger side head-dscn1095.jpg
99VetteFRC is offline   Reply With Quote
Old 04-05-2012, 11:05 PM   #14
ZQ8LS1's Avatar
Thank you for the pics.
My engine is out, so now is the time to deal with this.
Old 04-06-2012, 01:30 AM   #15
Not sure if I'm exactly on topic here, but if you are using an Autometer sender that comes with some of their gauge kits (which are too big to fit into their adapter......I'm assuming that is what you are referring to by saying you have to drill the 2277 adapter out) they make another sender that you can use with those gauges that fits directly into the adapter.
Autometer 2277 - 12x1.5 male x 1/8NPT -Adapter for LS -
Autometer 2259 - temp sender - short snout - fits the 2277 adapter
Autometer 2258 - temp sender - long snout - DOES NOT fit the 2277 adapter - (this one came with my gauges. I had to scrap it and buy the 2259 to make things fit).
Not sure if that helps.
66 BADBOY is offline   Reply With Quote
Old 04-06-2012, 12:46 PM   #16
i just did the 2277 and 2259. that's for the short sweep autometer temp guage.
edge04 is offline   Reply With Quote
Old 04-06-2012, 02:04 PM   #17
tfi racing's Avatar
Quote:
Same here,drilled and tapped head for 3/8" NPT OBS truck sender,nothing to it as long as the engine is still out of the vehicle.I used the Equus adapter and a 1/8" NPT to 1/4 NPT fitting for the oil pressure.Even with buying the tap at the local tool store,I'm into it for about $25.
tfi racing is offline   Reply With Quote
Old 04-06-2012, 02:43 PM   #18
TomM's Avatar
Quote:
Andy1
Next time, screw the sender into the adapter first, then into the head....don't ask how I figured this out.....
Quote:
That is correct, no tapping required.
T,
TomM is offline   Reply With Quote
Old 05-14-2012, 05:47 PM   #19
anyone else experiencing this with these adapaters used in the rear passenger head?
When first starting my car from dead cold, my temps will go up to 210 and then drop. I assume that is when the t-stat is fully opened. But, it only drops to 195-200. If I now shut it down, when starting back up, it will only be at 190-195. Not a big difference but seems odd to me.
Related Topics
Thread Thread Starter Forum Replies Last Post
Nitrous filter fitting baronsmith98 Nitrous Oxide 1 12-13-2016 01:25 PM
turbo turbo fittings,vacuum fittings, manifold bov fittings 1/8 NTP one fast zo6 Parts Classifieds 3 02-21-2016 09:21 PM
Fuel Sender AN Fitting - Compression or Weld 86SS86LS Conversions & Hybrids 17 09-14-2012 06:47 AM
Wtb: Y pipe to fit kooks 3 inch slip fit headers on a 99 firebird VIPERSLYR Parts Wanted 1 09-07-2012 09:16 PM
Fuel rail covers, will they fit an Fbody? mvvette97 Appearance & Detailing 7 01-16-2007 11:45 PM
Tags
2002, 53, adapter, adaptor, coolant, firebird, fittings, jeep, location, ls, ls1, mechanical, sender, sensor, swap, temp, temperature
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
