t56 clutch setup in 88 fox
Old 04-05-2012, 11:52 PM
eggnore's Avatar
Default t56 clutch setup in 88 fox
im attempting to get my parts ordered for my fox but am unsure where to mount anything or what other parts i need.
i liked the GM part in post 5 from this thread-https://ls1tech.com/forums/conversio...-cylinder.html, but would like some more direction for my particular application.
Old 04-06-2012, 08:38 PM
eggnore's Avatar
BUMP*
BTW no engine or tranny in the car, still has the cable setup
Old 04-06-2012, 09:23 PM
06colorado's Avatar
Easiest way will be to buy Mcloeds mustang hydraulic conversion kit.
Many have been using t-bird hydralic setups and fabing mounts to the clutch pedal.
Old 04-06-2012, 10:33 PM
zipster's Avatar
I fabbed my mount, I used the Wilwood 3/4 clutch master
I painted the pedal before final install, this set up gave me the correct throw. Cant remember if it 1 or 1 1/4 inches of throw.
Last edited by zipster; 04-07-2012 at 09:03 AM. Reason: had wrong size of master cylinder bore
Old 04-06-2012, 10:44 PM
eggnore's Avatar
wow that's pretty straight forward.
i like that, i saw another thread a couple mins ago that required a lot of fabrication to the entire pedal assembly but this looks like its pretty simple. thanks i will probably steal your idea if you don't mind
Old 04-07-2012, 08:55 AM
zipster's Avatar
Go ahead, I try to simplify things without breaking the bank.
Quick Reply: t56 clutch setup in 88 fox
