05 Caddy CTS-V engine/trans questions
Going the LS route with my 69 Chevelle and was thinking 6.0 T56 but I found an 05 CTS-V engine and T56 that includes ECM/harness etc etc is this a good combo to start with? Is a CTS-V T56 any different than an Fbody T56?
Thanks in advance.
Thanks in advance.
The shifter on the CTS-V is very different from the F-body/GTO T-56. It's something that you may be able to make work. Search the forums and you should be able to find the differences.
Edit...
Found it.
https://ls1tech.com/forums/manual-tr...me-f-body.html
The GTO T-56 shifter can be changed out for the F-body one if you change the shifter cup also (This is what I did).
Edit...
Found it.
LS1Tech Sponsor
Good motor. Remember that the CTSV is going to be running a green/blue PCM while the F-body ran a red/blue. Just an FYI.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
