68 Camaro SS - LS1/4L60e conversion - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 04-11-2012, 06:03 PM   #1
BK68SS's Avatar
Default 68 Camaro SS - LS1/4L60e conversion
I finally purchased an LS1 from crateenginedepot. I am very new to these engines so i have been getting alot of info from my friend (greasemonkeychef) who is doing a swap in a Nova. I just received the engine today so I created an account. I have been reading other posts for a while so I have started getting the feel of the site. I bought a long block so I will be researching for parts.
I have started doing the interior work while waiting for an engine. I started taking pictures so I can post info on the project
BK68SS is offline   Reply With Quote
Old 04-11-2012, 06:18 PM   #2
bczee's Avatar
Welcome.. Keep your Project thread going. Pictures..
anyway.. check out the Sticky/FAQ at the top, many builds are thre for you to research..
Fill us in on what you are going to be using for Oil pan, adapters, trans, etc..anyway.. let us know if you questions if you need to..
BC
bczee is offline   Reply With Quote
Old 04-11-2012, 06:25 PM   #3
BK68SS's Avatar
Thanks. I will get the pictures up, just trying to navigate this site for a bit.
Old 04-11-2012, 06:29 PM   #4
Welcome aboard Brad! This site is a wealth of info and great for parts. When he says check out the sticky's he means soon as you enter the hybid section you will see the sticky's in "yellow" at the top of the forum. There is a ton of info in there for parts needed and what not.
Now post some photos and before long you will be living on this site. Several guys are very helpful on here and some are PITA. Just dont be afaraid to aske questions here too. i am sure almost every question has been asked at least once and sometimes the search function is hard to find what you are looking for.
greasemonkeychef is offline   Reply With Quote
Old 04-11-2012, 06:30 PM   #5
Come on you work in technology this site should be a breeze
Old 04-11-2012, 06:35 PM   #6
BK68SS's Avatar
Ha ha. But I work on Macs there, need to learn the lingo here. This is like me signing you up to a unix forum.
Old 04-17-2012, 03:31 PM   #7
BK68SS's Avatar
Old 383 removed, packaged and sent to a buddy in Michigan.
68 Camaro SS - LS1/4L60e conversion-old_383_01.jpg
Old 04-17-2012, 04:24 PM   #8
Look forward to pics
bmf5150 is offline   Reply With Quote
Old 04-17-2012, 07:08 PM   #9
BK68SS's Avatar
Here is a pic of the car, the new crate engine and some interior work i am doing in the meantime...68 Camaro SS - LS1/4L60e conversion-floor_pans07.jpg
68 Camaro SS - LS1/4L60e conversion-camaro.jpg
68 Camaro SS - LS1/4L60e conversion-lsengine.jpg
68 Camaro SS - LS1/4L60e conversion-floor_pans06.jpg
Old 04-17-2012, 07:17 PM   #10
bczee's Avatar
Looks like you got one of the later LS1 blocks, you have a LS6 valley cover and PCV system, that's good!.
Keep up the work... we are watch ! LOL
BC
Old 04-17-2012, 07:25 PM   #11
going to be a sweet ride.
beater6.0 is offline   Reply With Quote
Old 04-18-2012, 01:01 AM   #12
BK68SS's Avatar
I have seen multiple oil pans used for the early Camaro build. Can anyone share their experience with the oil pan they chose? I am leaning toward a modified f-body pan. Any issues with this route?
Old 04-21-2012, 02:57 PM   #13
BK68SS's Avatar
After more research, I am now leaning toward autocraft oil pan and s&p mounts. I am planning on not running headers. This part is confusing to me, wish there was more of clearcut answer.
Old 05-01-2012, 12:34 AM   #14
Maybe someone can help me a brad on this question.
We are using a 01/02 camaro intake and harness for this conversion. Now do we need to swap the valley cover and knock sensors or will the newer style knock sensor plug into the older harness? If we change the valley cover then I believe we will then have to change the rocker cover then too? We are just trying to get up to speed on this part of the project. It may be a simple as the knock sensor harness will hook to these sensors and plug right into the main harness?
Thx for any help.
Old 05-01-2012, 08:09 AM   #15
LS1Tech Sponsor
psiconversion's Avatar
Knock sensor harness will plug right into your stock harness.
Jon
PSI
psiconversion is offline   Reply With Quote
Old 05-01-2012, 10:40 AM   #16
bczee's Avatar
The Autocraft pan is a good choice. If you looking at Cast pans, the MAST and Holley are also good choices.
Try and stay with the same manufactor on pans, mounts and header, Mixing and match can sometime lead to more work and additional cost. Check the project threads to see what other are using for pan/mount combo's. But with the newer pans, almost any mount will work now.
keep up the questions and pictures.. ( i get bored here at work during lighter days)
BC
Old 05-01-2012, 11:15 AM   #17
BC
Thxs for info on pans. From the pics brad put in the thread of the new engine did they sell him a LS6 rather thasn LS1? I am confused on the difference's. So from my understanding we can just get a knock sensor harness for the LS6 valley cover and it should have no issue with plugging into the 01 main harness?
Old 05-01-2012, 12:23 PM   #18
bczee's Avatar
The F-Body 01-02 had the LS6 block and intake, but still had the older PCV system, might be a Vette LS6 engine or maybe a CTS-V ? They are the same blocks. Not sure, but is nothing to worry about.
yes, the Knock Sensor should be the same for the Gen III engine. There is a few threads about doing the conversion (also on LS1HowTo) to the LS6 PCV on older blocks. It is a better PCV system and can be just bolted on to the 01'+ blocks, 00' and older needs to do some cutting and grinding on the block.
BC
Old 05-01-2012, 12:27 PM   #19
c6matt's Avatar
cool build.. sounds familiar somehow..
c6matt is offline   Reply With Quote
Old 05-01-2012, 11:16 PM   #20
Hey brad I also read today that some people are using a freeze plug to block the EGR port on the top of the intake. So we should just get a good measurement and buy a $3 freeze plug and call it done.
Also seem like we just buy a knock sensor harness for this motor and it should plug into the current harness. That is if I am understanding what others have posted.
Related Topics
Thread Thread Starter Forum Replies Last Post
New to LS1Tech from Iowa 40FordDeluxe Introductions & Greetings 3 01-10-2016 07:53 PM
New from SoCal With 68 Corvette heavily moded Z68 Introductions & Greetings 0 10-11-2015 12:33 PM
2010 LS3 and TR6060 in a 68 Camaro m0ondoggy Conversions & Hybrids 110 10-21-2014 09:25 PM
Lt header+ory install/review Speed Engineering GtoProject Generation III External Engine 14 12-11-2013 08:47 PM
I'm confused about oil pan, fuel and steering clearence with certain mounts - 68 bird Shawn MacAnanny Conversions & Hybrids 2 10-22-2007 07:36 PM
Tags
1968, 4l60e, 68, 79, camaro, engine, floor, ls1, lsx, michigan, pan, repair, sale, ss, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
