wiring a 2007 and up alternator?
Old 04-18-2012, 02:14 PM
bad67ls's Avatar
Default wiring a 2007 and up alternator?
2 pin connector, not 4. do i have to use the diode? which wire shoud get power?
it works as a 1 wire, but seems to drop off voltage as load increases...and i know my car isnt creating anywhere near the amp load this thing is rated for...
Old 04-18-2012, 04:52 PM
Docked Wage's Avatar
Are the 2 wires gray and brown?
Old 04-18-2012, 06:29 PM
Gray86hatch's Avatar
We run a set up like this. just the battery lead hooked up nothing in the two other leads
See voltage with everthing on. lights, ac and EFI about 13.5-6. Has not been a problem for us yet
Tim
Old 04-19-2012, 06:40 PM
bad67ls's Avatar
dont know what coors they are, i dont have the pigtail lol
it charges ok, but i thought maybe it would work better with the field wires connected.
Old 04-19-2012, 07:24 PM
The ECM controls it. Field wires won't do anything. Not like the older ones.
Tim
Old 04-19-2012, 07:34 PM
When you get the connector...
The brown wire goes to pin 15 of the Green ECM connector and the Gray wire goes to pin 75 also in the Green ECM connector.
The ECM will then control the Alternator.
Old 04-20-2012, 09:10 AM
bad67ls's Avatar
Its a carb setup. No ecm.
Old 04-21-2012, 12:42 AM
Gray is the Field Duty Signal so that needs 12 volts (Ign on).
Brown is for one side of the Idiot light. 12 Volts (Ign on) the other side of the light. Otherwise a 470 ohm resistor between this wire and 12 volts (Ign on).
Old 04-21-2012, 01:31 AM
bad67ls's Avatar
Thanks much docked!
Old 04-21-2012, 06:05 AM
Let me know how that works for you.
From the research I did 2 years ago you could not hook one up like that.
Tim
Old 04-21-2012, 09:59 AM
bad67ls's Avatar
?? care to elaborate?
Old 04-30-2012, 01:07 PM
1970camaroRS's Avatar
More info on this? 2 pin alternator need anything other than the charge wire to the battery/starter? Seems to be a split here between people that say wire the 2 pins or leave them empty.
Old 05-03-2012, 06:52 PM
bad67ls's Avatar
i have a red and a grey wire...no brown. now what? (off the factory harness)
Quick Reply: wiring a 2007 and up alternator?
