PRND input, Pin 34 - Confused?
Old 04-24-2012, 01:15 AM
Bullitt4110's Avatar
Default PRND input, Pin 34 - Confused?
What are people doing for this? I realize that the circuit has to be grounded in N and P, but from my understanding most older cars neutral safety switch sends a 12v in N or P (I have a B&M shifter). And according to LT1swap Pin 34 "P Input" is the only input Ill need. I am probably over thinking this and thinking it is way more complicated than it really is, but I havent dealt to much with auto transmissions. Any help would be greatly appreciated. Thanks.
Old 04-24-2012, 09:39 AM
bczee's Avatar
There was a few posts on this and someone posted a wiring diagram on using a Relay setup with the activation being the old PRND wire (hot 12+ volt) and the relay setup giving the ground to the PCM, Anyone got that thread ?
BC
Old 04-24-2012, 09:46 AM
bczee's Avatar
Ok. .found one of them..
https://ls1tech.com/forums/conversio...-question.html
Old 04-24-2012, 12:04 PM
Thanks Brain, Ill give that thread a look over when I have some more time.
Quick Reply: PRND input, Pin 34 - Confused?
