S10 Xtreme L33 swap!
Old 07-02-2012, 11:50 AM
  #41
hotrodscrap's Avatar
Originally Posted by zdiesel
Yup, keeping both AC and heat! She's my daily so both are pretty necessary.
Good choice, I'm sub'in for updates. Keep em' coming!
-SS
Old 07-10-2012, 03:12 AM
  #42
bamaballa205's Avatar
5.3 Were made for these trucks.
Old 07-17-2012, 10:30 PM
  #43
zdiesel's Avatar
Alright, so got some parts in.
Holley Oil pan...
Parts from Summit; Fuel line, AN fittings, oil filter, oil pan gasket, dipstick, dipstick tube, and clutch alignment tool. Also got my bronze pilot bushing in.
Part numbers for fuel fitting for 2.2 flex fuel truck (need two of the straight hose ends)...
Flywheel resurfaced and spacer for it...
And then hit a road block, pulled the pan off and fitted the pickup tube, windage tray only needed some small filing for the pickup bracket to clear. And then I was looking around and I noticed this...
Crack in the block where the starter mounts, pretty upset about it. Calling up my machinist tomorrow to see when I can get it to him to weld up. Truck starts coming apart this weekend.
Old 07-17-2012, 10:45 PM
  #44
Crazier's Avatar
Nice crack
I will be watching cus l33 seems to be rare on this forum, yours is a lot lower miles then mine though, wanna trade?
Old 07-18-2012, 11:18 PM
  #45
zdiesel's Avatar
I've seen a lot more L33 builds starting to surface lately. No trade, this puppy is all mine I hunted for a while to find a good low mileage pull out.
Engine is loaded up in the back of the truck, heading to the welder in the AM to get the crack fixed. On another note, I've ordered my air intake, mufflers, and my wiring harness should be coming in any day
Old 07-18-2012, 11:54 PM
  #46
Crazier's Avatar
Prices seem to be coming down on the l33. in reality I think they were far overpriced, unless your really cutting pounds they arent much better then any other 5.3. whats 150 lbs in a 3000 lb 350 horse set up?
Cept, its jsut cool to have one
Old 07-19-2012, 01:45 AM
  #47
Damn that crack sucks.
Old 07-21-2012, 11:11 PM
  #48
zdiesel's Avatar
Some updated from the past few days, things are starting to get rolling here.
Crack has been welded up...
Replaced the rear main seal gaskets since they were in such close proximity to the welding.
Got my Holley oil pan bolted up...
Then I threw the truck on stands, and the fun begins.
And here's how she sits at the end of the day.
Doesn't look like much but the exhaust is off, driveshaft is out, whole front faschia is off, fluids drained. Hoping to get the engine pulled out before next weekend.
Old 07-21-2012, 11:16 PM
  #49
mgrm's Avatar
Love progress.
Old 07-22-2012, 10:21 AM
  #50
ch0425's Avatar
Great build, what A/C compressor are you using?
Old 07-22-2012, 06:02 PM
  #51
zdiesel's Avatar
You can sort of see it in the picture of the oil pan on the engine. It's a Denso compressor from the Silverado it was pulled out from. The fittings attach a little more forward then like an fbody compressor, which helps them clear the control arm, the f-body ones tend to interfere with the control arm. If you want me to get a better picture of it or part numbers for you I can, just let me know.
Old 07-23-2012, 08:20 PM
  #52
ch0425's Avatar
The part number would be great, i would like to mount the compressor up top but i have the alternator there so im going to have to pull the engine back out to notch the frame.
Old 07-24-2012, 12:18 AM
  #53
zdiesel's Avatar
15244321, that number is on the front of the pulley and what I used to search for an AC compressor on ebay. My pullout came with the same one but it was mangled. Here's a shot of some other part numbers...
And time for an update.
Who likes progress?
I know I do...
Finally after 3 hours we wrestled that pile of scrap metal GM calls an engine out. Next thing to do is give the engine bay a cleaning and work on cutting my AC notch.
Part's will be flying through the door all week for this. Got some new stuff now though. eBay Silverado intake, saw someone else use it so I figured I'd give it a go.
Catalytic converters...
but not really
Old 07-24-2012, 05:08 PM
  #54
ch0425's Avatar
i appreciate the part number and picture!
Old 07-25-2012, 11:47 PM
  #55
zdiesel's Avatar
Not a problem!
Wiring harness came in...
Old 07-26-2012, 10:33 PM
  #56
zdiesel's Avatar
Got some stuff done between work shifts this week. Pulled it outside and hit the engine compartment with a tonnnn of foaming degreaser haha...
Looks a lot cleaner now.
Started pulling the interior out, will finish that up tomorrow AM.
And my magnaflow mufflers and T56 speed bleeder came in. Went for two 18" case magnaflows, the speed bleeder is from Speedway USA, was half the price of the tick performance unit, doesn't have the check valve though so I'll have to bleed it like you would brakes, but it makes it a hell of a lot easier to reach haha and I couldn't justify $60 for a speed bleeder I'll probably use only a handful of times. I'll save the money and just get a friend to help me lol
Old 07-30-2012, 09:23 PM
  #57
zdiesel's Avatar
Small update. Got some parts in...
LPW Girdle, and some stainless v-band's with mild steel flanges for my modifying my manifolds.
Test fitted the motor, k-member does need to be notched with the holley pan, started that notch and need to start my AC notch, no pictures of that progress as of yet though.
Old 08-04-2012, 08:53 PM
  #58
zdiesel's Avatar
Got some more parts in! Two e-fans, and a battery relocate kit to put the battery in the bed.
Picture of my notch cut k-member.
Spent the day cutting up the plate, man do I need a bansaw. Welded it up, thought I did damn well for first time actually welding up a frame! Need to still cut the side pieces out and weld those in, going to do that tomorrow and start cutting the AC notch.
Fitted the engine to check oil pan clearance and mark for my ac notch. Oil pan has much more room now, I'll take pictures and post some of the pan clearance when I get the motor back in to test fit the AC notch clearance.
Finished pulling my interior out to, gonna work on a cover panel for the old shifter location tomorrow. Clutch and flywheel are on the engine now and the trans will be bolted up next time it goes in as well so I can cut the new shifter location.
Old 08-04-2012, 09:06 PM
  #59
blknSS's Avatar
Nice, should be a fun truck. What part of Maine? I've live all over that state except far north.
Old 08-04-2012, 10:08 PM
  #60
zdiesel's Avatar
Falmouth right now, up in Orono when I'm at college.
Quick Reply: S10 Xtreme L33 swap!
